Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Oven electric starter not firing
The burners electric starter is working
    Sergeant:
  • 359 Answers
USUALLY IGNITOR WOULD REPLACE IT FIRST LESS EXPENSE THAN CIRCUIT BOARD AND GOOD START
Posted on Dec 23, 2008
Electric Oven will not heat or come on
Sounds like you have burned out the element?
Aug 12, 2015 | Ovens
Thermador Professional Oven
hey man don;t worry i have too much solution if i explain u every thing then you confused so i explain one and if u want another then e-mail me on mango4529@rediffmail.com so listen carefully
Step 1: Turn off the power supply, both gas and electric, to the range. Then remove the burner.
Step 2: Soak the burner in a solution of mild household detergent and water. Clean it with a soft cloth.
Step 3: Clear the gas ports with a pin or needle, rinse the burner, and let it dry. Caution: Do not use a toothpick or matchstick to clean the gas ports. If the tip of the wood gets stuck in the burner ports, it could cause a serious blockage.
Step 4: When the burner is completely dry, replace it, and turn on the power and the gas supply.
An oven that won't heat can occur for a variety of reasons.
and if not then open this link http://home.howstuffworks.com/how-to-repair-an-oven.htm
Nov 23, 2007 | Thermador POD301 30" Pro Series Deluxe...
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore Model No. 362.72505890 Gas oven will not get hot. The element comes on but the burner will not fire up. It did this last weekend but after rotating the temperature knob a few times it finally got...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 30, 2011 | Kenmore Ovens
Gas stove with electric starters for the burners. One keep clicking after it lights. How do you stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 02, 2011 | Thermador Professional Series PO301...
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Oven sometimes does not fire up
Is this a gas unit? There maybe a problem with the burner ignitor, it looks like a glow bar, if it is on it's way out, you will start to get intermittent operation, it should draw at least 3.2 amps, and is located right next to the bake burner itself, if this is an electric oven then there are a multitude of problems that may exist
Jun 15, 2009 | Ovens
Gas range won't work
Hi, Even tho the ignitor is glowing, it can be bad. It has to pull enough amps to open the gas valve. This is very common problem. I can get you the part and or prices if you could get me the model#
If I can help further, please let me know.
Thanks
Vic
May 15, 2009 | Magic Chef 9122 Gas Single Oven
How to light oven with electric power off?
Sorry, but this oven will not work without electricity. Looks like stovetop suppers for a few days. Hope this helps!
Jan 28, 2009 | Ovens
Wolf oven stove top starting problem
This is caused by a bad flame sensor switch. It has a cap tube (copper line) coming from the pilot area to a switch with two wires on the backside.
Hope this helps You
please rate me
Jun 02, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
44 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
