Question about HP Compaq Presario V2000 Notebook
CompaQ V2000 touchpad/mouse problems
I removed and reinstalled the synaptics drivers but problem continued. I then reformatted the root drive and did a reinstall of the WinXP backups from the D drive. The computer still has trouble. When you use the touchpad or a USB mouse, the cursor goes everywhere but where you want it to go. It will function well around the perimeter for the screen but as you get into the middle, it has a mind of its own. Ideas?
    Scholar:
  • 94 Answers
The touch pad is shorted.  In technical terms. The capactive field of the X-Y Matrix is shorted. This should be open until you run your finger across it, but since it is shorted, the center is no longer function properly.
You may have to get a completely new top plastics, if the pad is a part of it.  Earlier models were one piece.
Posted on Jan 03, 2009
Cant turn off the touchpad on my compaq presario cq50 & it's driving me nuts. HELP!
Hi Madre - Looking at the manual I can understand your frustration.
To turn the touchpad on and off you have to use button #6 (see below). Most certainly not intuitive!
Enjoy your real mouse.
Mikeywaf
May 19, 2011 | HP Compaq Presario CQ50-110US Laptop
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
Turned on my v2000 and the mouse pad is dead, wireless mouse works fine,
try reinstalling driver for touch pad. also do registry check sometime your registry gets scrambled and you lose devices as a result. run a registry program first. u can get one at www.majorgeeks.com for free. if that doesn't fix ya up reinstall the driver for the tft pad or mouse pad as u called it
Sep 21, 2009 | HP Compaq Presario V2000 Notebook
Laptop touchpad won't stop scrolling.
1. hook up a usb mouse to get you by.
2. try to download the synaptics touchpad driver.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
see if that helps.
Sep 14, 2009 | HP Compaq Presario V2000 Notebook
Touchpad will not work
Hello, seems like a problem with the touchpad, first disable and enable the touchpad with the button which is located at the top of the touchpad, the corresponding LED should change from blue to orange and vice versa. If this doesn't solve the issue, reinstall the driver for the touchpad, you can find this by searching for 'recovery manager' in the start bar. Next step is to select 'advance options' and choose reïnstall hardware driver, there should be an option called 'Synaptics touchpad driver' select and install. kr Gijs
Sep 10, 2009 | Compaq Presario CQ60-220US PC Laptop
Synaptics touchpad mouse will not move cursor
Update synaptics driver from Hp.com that should fix the issue
May 16, 2009 | HP Compaq nc6220 Notebook
My touchpad wont work
Go to control panel + mouse + device settings to see if the synaptics touchpad is enabled otherwise you can download the touchpad driver from here to reinstall it. Post your results back here.
Feb 25, 2009 | Compaq Evo N600c Notebook
My touchpad mouse and didn't working(presario v2000)
it could be the touchpad connector/cable get defect....
mouse drive barely have problem as it given by Windows ,
can try and order a touchpad set from ebay,and if that dont work,
guess you'll have to get a USB mouse for that.......
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
Touch pad is not working--COmpaq Presario B1900
Hold down the FN Key + F6 (OR the corresponding F key for the touchpad)
The B1900 can have its touch pad turned on and off.
Its a good feature when you just want to use an external mouse.
Hope this helps
Jul 04, 2008 | Compaq Presario Laptop
HP Compaq Presario V2000 Notebook Logo
299 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
