Question about Denon AVR588 Receiver
I have my set-top box connect to the tv/cbl port of my denon avr-588 receiver via hdmi, and I have another hdmi cable from the back of my tv to the monitor out port in back of my receiver. I get a video signal for about 10 seconds and then it goes out, comes back on, and goes out. I have audio the entire time. Please advise.
The hdmi ports are damaged. Composite video works fine, just not hdmi
Posted on Dec 14, 2008
I have a denon avr-1611 and can get sound playback through my connected speakers (not tv speakers) but no video output from hdmi. I have the receiver connected to a samsung tv. Is there any fix for th
You should check your Denon manual to be sure that the receiver has been set up correctly. My 1913 has many set up options including associating a particular HDMI out connection with a particular source like CBL/SAT or DVD. The fact that you hear sound indicates the HDMI cable connecting the cable box or DVD player to the receiver is working ( at least the sound portion of the HDMI in cable.)
Next, is the HDMI connection you are using to the TV the one selected in the source listing on the TV ? The sound and video circuitry on a receiver are separated and you can hear sound but see no video if the TV isn't selecting the correct source. For example if the TV is set to HDMI1 but you are plugged into HDMI 2. If this doesn't solve your problem try this:
At this point you don't know if the problem is the receiver HDMI connections or TV HDMI connections or a bad HDMI cable. The first thing to try is a new HDMI Cable. If that doesn't solve the problem then do the following.
If the TV has more than one HDMI connection try another HDMI port. Be sure to switch the source on the TV to the new HDMI port ie. HDMI1,HDMI2 or whatever.
If this fixes the problem you are done. If not then Try the same thing with the HDMI out ports on the receiver. Try each one not forgetting to set the receiver to use the HDMI port you are testing.
each time.
Since this can get confusing I would write down what you are testing each time so you don't get lost or confused.
If none of this works then you can try hooking up another TV to the HDMI cable, if you have one. If you do this and you still have a problem it points to the receiver as being the culprit.
The most likely problem is you have misconfigured the system so that is where I started. Each test is dependent on the fact that your system is correctly configured to begin with.
Sep 04, 2014 | Denon AVR-1611 A/V Receiver - 3D - 75 W...
I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Jan 12, 2012 | Denon Audio Players & Recorders
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
Connection problem with HDMI cables on Denon AVR-589
I want to clairify you install, you sat you have I an HDMI cable running from the Time Warner Cable box to the AVR-589, going in to the TV/CBL input. From the Denon AVR-589, I have an HDMI cable running from the output to my Toshiba RV525U television.
Check the connection at the TV, if as you indicated above you have an HDMI cable from the HDMI out from the Denon to an HDMI output on the TV, if this is the case you need to have that HDMI cable plugged into an input on the TV not an output
Feb 27, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
No Video from Denon AVR-588
It cant up-convert component to hdmi. Input and output has to be the same. However, you wont lose anything cuz hdmi and component are comparable
Nov 24, 2008 | Denon Audio Players & Recorders
Denon AVR 588 7.1-- Sound setup questions
This reciever does not decode the audio through HDMI, the HDMI ports are simply a pass-through. To get audio you need to connect an optical audio cable from the PS3 to the reciever also. I figured this out after 2 hours of trying to get audio from the HDMI cable. Here is a link that shows the different audio formats supported through HDMI by the different Denon models. It looks like the AVR-788 is the lowest model that supports audio through HDMI. Hope that helps.
Apr 03, 2008 | Denon AVR588 Receiver
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Denon AVR588 Receiver Logo
167 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
