Question about Samsung Televison & Video
Hi, does the samsung 32" LE32A330 have a headphone socket. If not is there any connector I can use to hook my headphones up with the existing ports?Thanks MConn2008
SparkGap
  • 363 Answers
SOURCE: Headphones
This TV does not have a headphone socket, which is unusual. There are audio outputs (RCA phono) which may be used with an amplifier or tape deck to drive the headphones.
Posted on Oct 08, 2007
SOURCE: Hitachi L26H01U headphone socket doesnt work
User problem!! The main TV volume and the headphone volume work independently so you can have the TV volume set at zero and use the headphone volume. However I suggest getting a pair of headphones with it's own volume control.
Posted on Dec 27, 2008
  • 1894 Answers
SOURCE: How to connect headphones without a headphone socket
if there is differentiation between the sockets you will need the manual..
Posted on Mar 09, 2009
  • 3 Answers
SOURCE: TRYING TO HOOK UP HEADPHONES,IS IT CAPABLE.
Hello, IF your tv is capable of using headphones it will have a little jack with a head phone symbol over it or under it most likely. IF not you can buy a home theater system which would hook up to your tv and some of these have an option to hook up headphones or even ipods and usb devices.
the greek
Posted on Jun 06, 2009
SOURCE: Need headphone solution for Panasonic c12lcd tv
I have a Panasonic viera 32in lcd hd tv. I'm trying to hook up headphones but there's is no apparent audio output jacks. But there's is only one digtal output jack! is this the jack ? and if it is, what cables do I need to make the headphones work? or am I forced into by an amplifier
Posted on Nov 22, 2009
My sony wireless headphones will not work with my new 32" Veira TV when I plug them into the audio ports white/red?
Hi,All the RCA sockets are inputs so you won't be able to plug in your heaphone transmitter into those.
From what I can gather you will need to plug the headphone transmitter into the 3.5mm Jack socket located on the right hand side of the TV near the RCA sockets.
If you only have RCA plugs on your heaphone transmitter you will need one of these pictured below.
You can get them from Maplins electronics or Radioshack if in the us or any good audio outlet.
Hope this helps.
Feb 11, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
No sound comes out of the tv speakers, it used to be hooked up to suround sound but not anymore.
Hi
Can you hear sound from headphone socket if so cheek speakers and clean or replace headphone socket
regards windyhouse
Mar 24, 2010 | Televison & Video
Samsung LE37R888D LCD TV. No sound from the main speakers or Line out.
    This problem arises due to cross pin connection of the headphone socket.Mostly frequent use of the headphones result this situation (no sound via external speakers). Call any service man he will provide you the services at nominal charges. And if you can do it by yourself then approach to the headphone section and just adjust the headphone pin, This will solve the problem.
Thanks for using fixya.
May 21, 2009 | Samsung Televison & Video
Can i use headphones on the nc10 ?? if so, which socket ??
It appears that on the right hand side of the notebook you should see a green socket. It most likely has a picture of headphones or so. This is how you may use your headphones.
Let me know if you need any more help with this.
Apr 19, 2009 | Samsung NC10-14GW PC Notebook
Mar 09, 2009 | Insignia 37" LCD Flat-Panel HDTV
Working on tv/playstation 2
You can easily buy RCA conectors and splice them. Remove the 1/8 plug from the speakers and strip the ends and add the RCA connector. I am not so sure of what it would sound like but the ohms may be different.
Nov 06, 2007 | JBL CREATURE II Computer Speakers
Open Questions:
Televison & Video Logo
70 people viewed this question
Henry  Thomas
Henry Thomas
