Question about Cameras
My battery cover for my Toshiba PDR-M700 camera is broken. It won't keep the batteries in place enough to hold a charge. How can I get it fixed? I tried a local camera place and they don't fix this kind. I know it is an older camera but it still worked well.
EVision Clearview my batter cover is broken, I live in 48235 area ( Det Mi) I need repair location?
Posted on Dec 18, 2008
My PDR-M700 Digital Camera will not connect to my computer when i plug it in with a USB
If the camera will work from USB, install the manufacturers software and drivers first.
Apr 08, 2017 | Toshiba PDR-M700 Digital Camera
Lost disc for toshiba pdr-m 700 need to dowload online where?
Here is a tip that I wrote about how to find the manuals, drivers, downloads and support for Digital Cameras.
Digital Camera Manuals, Drivers, Downloads, and Support
This site says they have the drivers that you are looking for...
http://download.driverguide.com/driver/PDR-M700/Toshiba/d1284434.html
heatman101
Apr 22, 2011 | Toshiba PDR-M700 Digital Camera
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
PDR 3330 WILL NOT TURN ON
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 21, 2009 | Toshiba PDR-3330 Digital Camera
I press the shutter button a red light flashes in the viewfinder
Your focus or lighting is too low for the picture. Add more light, and hold the button down half way to self adjust to see if it goes away. Change the battery to a lithium battery, which helps the digital cameras work their best.
Let me know if this helps.
Jan 24, 2009 | Toshiba PDR-M700 Digital Camera
Toshiba PDR M700 Slideshow
Have you tried pressing the 'down' button?
Good luck.
Aug 12, 2007 | Toshiba PDR-M700 Digital Camera
Charging battery
Hi Pat, When charging the battery the light should definitely be red. When it turns green it's charged. I would exchange your camera for another PDR-M5 if you can. I actually had to do the same thing - noticed a big difference with the second one - including fit and finish....think that maybe Toshiba has a quality control issue. I just returned mine (second one) yesterday - was a hard decision - love the features - 3X zoom - video - speed, etc.....but got fed up with the picture quality indoors - too many out of focus - couldn't count on it. Also all pictures - in/out - tended to be dark - drab looking - always had to lighten using the software before printing. This is a $1250 camera in Canada after tax w/extra 16 meg smartmedia which you need at the minimum so there are no excuses. Hope you have better luck with yours!
Sep 15, 2005 | Toshiba PDR-M5 Digital Camera
Poor exposure when using the flash
I read in another Toshiba forum where some users were putting a small piece of electriacal (black) tape over the flash sensor, and their indoor photos with flash turned out spectacular, since it allows the camera to apply more light . Actually fools the camera but it works. You might want to experiment with it..
Sep 15, 2005 | Toshiba PDR-M700 Digital Camera
Battery
there could be few reasons for that: 1. You are using the camera in extremely cold conditions - Put the battery in your pocket or another warm place to heat it and then load it into the cameras just before taking a picture. 2. The terminals are soiled - Wipe the battery terminals with a clean, dry cloth. 3. The battery has reached it's effective life - Load a new fully charged battery.
Sep 15, 2005 | Toshiba PDR-M3 Digital Camera
Cameras Logo
59 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
