Question about XM Radio (XMP6000)
XM radio static.
Installed XM radio in 05 F-350 Super Duty 4 door with lumber rack. Have tried mounting in a couple different locations, yet still hear static unless touching the unit with my hand. As soon as I move my hand away the static returns.
3 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: Need an In Dash XM Radio Installed on 1997 Honda Prelude
well...there is an after market for this, but it's a little high end at this point.
Posted on Jun 18, 2008
yammy_alf
  • 666 Answers
SOURCE: My xm radio has a lot of static no matter what
check from your so rounding if have electric motor running. that machine also give static response to your radio unit.
Posted on Apr 05, 2010
My 2007 ford F150 stereo cuts out intermittently when the headlights turn on both with the auto setting and when turning on manually
Intermittent windows, gauges, radio - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > Super Duty & Heavy Duty
Dec 4, 2009 - Intermittent windows, gauges, radio Super Duty & Heavy Duty. ... How about headlights, which you didn't mention? Does the vehicle .... You know how when you turn off your truck, and the radio continues to play until you open a door? .... I cutthe corroded section out and put on a new battery terminal. Radio cuts out when headlights turned on
Oct 24, 2013
Headlights on and radio turns off...
Dec 28, 2010
Electrical Glitches / Electrical / Electronic Diagnostics / Fixes ...
Dec 9, 2009
Odometer Blackout Problem Fixed!!!
Jan 25, 2004
More results from www.ford-trucks.com
Nov 24, 2015 | Ford Cars & Trucks
Xm check atenna connection
If you are getting the same "check antenna" message with two different antennas, it is likely that the tuner itself is the problem. You can get just the mini tuner here:
http://www.tss-radio.com/products/xm-mini-tuner-replacement-home-dock
As far as the two plug connection, there are adapters available. Its likely a dual fakra connection, though I don't know for sure. At any rate, this is one adapter available. (I would call to confirm)
http://www.tss-radio.com/products/sirius-dual-to-single-antenna-adapter
Jun 27, 2012 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
XM radio is not working. Tries to 'Load' but then says 'no signal'. XM says that I am receiving the signal but Honda says there is no problem. They want to try to replace the antenna for $500 but are...
You best bet - if you can get to the rear of the XM tuner unit, is to temporarily connect a magnetic-mount XM antenna and see if it works. A bad antenna usually says "check antenna" - not loading could be a good antenna with a bad location. I would try the little XM antenna by itself, then go from there. $20 is a lot cheaper than $500. Let me know how it works out.
Oct 30, 2009 | XM Radio XM Direct 2 Mini-Tuner Car Kit...
No audio through car radio
is your car radio and the xm receiver tuned to the same frequency?
Aug 31, 2009 | Delphi SKYFi XM Radio Receiver
Hissing/static
check all ground wires for radio and xm and make sure xm antenna is mounted on metal surface
Mar 28, 2009 | XM Radio (XMP6000)
Factory Installed Problem
you would need to add a different xm antenna. I believe the plug in is the sam on them like one for an add on xm radio could mount it on hood maybe so you would not have to mess with again.
Dec 17, 2008 | XM Radio (XMP6000)
Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
Apr 08, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Jul 30, 2007 | Audiovox XCS9 XM Radio Receiver
Car Audio & Video Logo
79 people viewed this question
Top XM Radio Car Audio & Video Experts
xxxxxx xxx
John
John
Are you a XM Radio Car Audio and Video Expert? Answer questions, earn points and help others
