Question about Garmin Edge 705 Handheld GPS Receiver
Edge 705 does not power up
Resetting by using mode + restart/lap does not work
  • paul partr Dec 24, 2008
    I have exactly the same problem with my 705 unit will not power up, has been fully charged, pressing reset+mode simultaneously does nothing ?
When you want to give a hard reset you have to press the mode button en the on/off button, after a few seconds you get a question if you want to delete some things.
Posted on Feb 05, 2009
How i can hard reset on my garmin edge 705
Hard reset : To perform this one holds down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Feb 01, 2017 | Garmin GPS
How i can hard reset on garmin edge 705?
Hard reset : To perform this one hold down the mode button while powering on your Edge, the Edge will ask you if you want to reset it, this should wipe clean the 705, all data will need to be imputed again.
Only screen is the garmin logo with the battery charge icon. When power button is pressed another icon appears for 20s: a picture of the garmin unit linked to a charger then back to the first screen.
Don't know if this will help but it might be worth trying, especially if you just did a software update. I have a 520 and it gets frequent software updates. After an update it ends up just showing the Garmin screen and seems to be bricked because nothing else works - even the off button doesn't work. The solution is to just let it sit showing the Garmin screen for five or ten minutes so it can process and load the new software which seems to take a long time. It eventually opens onto the main screen.
Oct 07, 2016 | Garmin EDGE 705
Factory resettings for garmin 705 edge
To hard reset the unit turn the unit off, hold down the mode button and turn the unit on. When the unit asks if you want to erase all user data, select yes. After resetting the unit, leave it with a clear view of the sky for about 30 minutes to acquire the satellite almanac
Aug 07, 2011 | Garmin Edge 705 Handheld GPS Receiver
Garmin edge 705 will not turn on
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Nov 08, 2010 | Garmin Edge 705 Handheld GPS Receiver
Sorry but honestly...Since GARMIN launch the EDGE this problem is still not resolved by them. The EDGE 305 had the same problems. Just search the www and you will see. My 705 died on me after just 2...
Edge 205 or 305 or 705 or 605 often crash, then impossible to power on again.
Nov 01, 2010 | Garmin Edge 705 Handheld GPS Receiver
Garmin Edge 705 Frozen
Only hard reset cleans up memory, when corrupted.
Hold Mode and Start buttons for 10 seconds (device off). Then without releasing pulse press lap/reset button, you'll get a screen for confirmation, all data lost, including user data and routes.
May 14, 2010 | Garmin Edge 705 Handheld GPS Receiver
Cant delete gpx files from 705 edge memory. done all usuall stuff on pc, even tried deleting gpx folder but routes still appear in saved rides when unit re-powered up. any ideas anyone?
Only one idea ... Perform hard reset. Garmin devices have often data corruption issue, that can only be solved by return to factory settings :
Device powered off, press and hold mode and Power on buttons for 10 seconds, then pulse press lap/reset button.
You will be asked for confirmation, confirm, your device should be OK then.
Also update the firmware, you'll get last fixes for data corruption ... (does not mean there are none remaining ...)
Jun 24, 2009 | Garmin Edge 705 Handheld GPS Receiver
Edge 705 wont switch on
Had a similar problem. Try a combination of lap-reset button and mode button THEN power button.
Jun 08, 2009 | Garmin EDGE 705
Excited with new toy.
Soft Reset: Mode + Lap. Then power on.
Hard Reset: Power On + Enter (down on thumbstick)
Hopefully this will fix your problem.
Apr 02, 2008 | GPS
Garmin Edge 705 Handheld GPS Receiver Logo
673 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
