Question about Kitchen Ranges
Kenmore elite double oven control panel
Only the oven stop buttons work. It seems to be locked.
  • buckeyejh Feb 01, 2009
    Same here, the oven worked fine yesterday. The only buttons that beep are the upper and lower oven stop buttons.
I just purchased the kenmore elite double oven with the touch pad control centre. Has anyone had any problems with the control panel on these ovens?
Posted on Nov 18, 2009
    New Friend:
Control panel says sabbath can't turn on stove
Posted on Mar 03, 2013
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Push buttons do not work but shows time
Sounds like the control panel is faulty. We've gone through two of these already, with the same issue.
Eventually, the plastic surface of the control panel bubbles up from the backing, especially over the clock. This is probably disrupting how the button-presses are being processed.
The control board is quite expensive ($250++ repair).
This is not an igniter problem. It's a lemon.
Aug 10, 2012 | Kenmore Kitchen Ranges
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Kenmore Elite speedcook oven Model 63799. F2
    f2 error means : -------
    1. The oven temp has risen above 665F and the door is not locked or
    2. The temp has risen above 965F with the door locked
    ------------- if this happens you should check: -----------
    1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
    2. Check and replace oven temperature sensor if necessary
    keep updated,please do accept and rate the solution.thanks.
    Sep 30, 2009 | Kenmore 63792 Microwave Oven
    Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
    I have this problem also my control panel is not working. It has an Er If on the panel.
    Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    Kenmore elite quiet pack 4
    You may have inadvertently locked the control panel. You should be able to clear it by pressing and holding the DRAIN/SPIN button for 3 seconds. (It should have Control Lock instructions listed righ under this button).
    Jun 17, 2008 | Kenmore Elite HE4 Electric Dryer
    Kenmore elite oven lock
    None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
    Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
    Kenmore elite microwave oven displays "Locked" and will not respond
    My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
    Mar 01, 2008 | Kenmore 62622 Microwave Oven
    Kenmore Elite Electric Range, Display stuck on LOC
    I pressed the lock icon on the panel and held it for a few seconds and the display cleared.
    Feb 03, 2008 | Kitchen Ranges
    Kitchen Ranges Logo
    824 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
