Question about Dell 1815dn All-In-One Laser Printer
Lines going thru the pages of fax i send
Dell 1815dn printer
prints pages well
when fax out the person i fax to see's many lines going thru the page up and down and the acknowlegement that is printed for me also has lines going thru it
recieving faxs do not have lines
jack
  • 2 more comments
  • jp7020 Dec 13, 2008
    scans are clear fax going out are not.. coming in are clear
    and the acknoledge page also has lines going thru it on both about ever 1/2 to 1/4 inch space verticale covering the whole page
    i fax thru the doc feeder
    thank you all for you answers
    jack
    copies going thru the feeder come out perfect
    only with fax going out but not coming in
  • JDTec
    JDTec May 11, 2010
    are you faxing from the Document feeder or from the scanner glass? If from the document feeder, lift the scanner and look on the right side. you will see a narrow glass. check to see that there isn't any specks, or dust on the glass.
    What happens when you place something on the scanner glass and press scan?
  • JDTec
    JDTec May 11, 2010
    If it scans a copy ok from both the scanner and the ADF, then there is a logic problem on the fax circuitry. I assume that it is out of warranty?
    I will research it a bit and let you know later.
    President:
  • Dell Master
  • 990 Answers
You ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Posted on Dec 13, 2008
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
How do I clear memory on incoming 500 page fax that I dont want to print?
Joan Dalgleish,
Click the link below to download the online manual. The manual
provides information for cancelling faxes.
http://dell.to/1SZ1G91
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 18, 2016 | Dell 1815dn All-In-One Laser Printer
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Aug 21, 2015 | Dell Office Equipment & Supplies
How to Determine the Printer Total Page Count on a Dell 1815dn laser printer?
Press the scroll button <--- highlight menu,
select (checkmark)
scroll to Reports, select
scroll to system data, select
Print out will contain the page count
Aug 10, 2011 | Dell 1815dn All-In-One Laser Printer
My dell 1815dn when printing also prints random symbols on top of the document. It varies from one line of random symbols at the bottom of the page to about 4-5 lines of random symbols sometimes. I've...
This is most probably a corrupt driver so try the following:
1. Open Printers and Faxes on your computer and delete the driver for your printer. Then go to dell.com and open the drivers and downloads tab. Download and reinstall your printer. If the printer is still printing out symbols, it's most likely either a problem with your connection or with the printer's hardware.
2. Try using a different cable to connect the printer and computer. If you don't have one, connect and install the printer to another computer. If this stops the symbols then you will need to buy a new cable. If it does not then it is most likely a problem with the printer's hardware and you will need to get the printer serviced.
Thank you for using FixYa!
May 25, 2011 | Dell 1815dn All-In-One Laser Printer
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Fax doesn't go thru.
Unplug the Power Supply from the printer.......
Press and hold the Stop/Clear button on the Printer and Plug in the Power Supply while holding the Stop/Clear button it should say clearing on the screen at that point u can go ahead and release the Stop/Clear button..........
Now the Printer will ask for the Date Time and Country Language.........
Set everything up......
Now try to use the Printer or try to send a fax it will work Fine...............
Issue Resolved................
Feb 13, 2009 | Lexmark X4270 All-In-One InkJet Printer
Dell 1815 dn prints lines in faxes going out
Dont think its your printer, try faxing to someone else and see if it happens there too.
Dec 11, 2008 | Dell 1815dn All-In-One Laser Printer
Fax Transmission fail from Dell Laserjet 1815dn
what do we do if our dell fax machine lazer mfp 1825 doesnt send or recieve faxes?
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
207 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
