I removed my SIM2 HT200 projector lamp and ordered a new one, which I have. Unfortunately, I did not properly mark which of the two projector wires is the ''positive'' wire. I suspect that although it is plugged into AC the wires seem to run through a ''diode'' that may be a DC converter. I do not have a testing gauge. One wire is longer than the other. Can you tell me if the long wire or the short wire is the positive post wire? Or do you suggest I run to radio shack and get a testing gauge?Thanks,TomChanhassen, MN
I tested the wires and discovered that the short wire is the positive wire. The DC voltage is extremely high and burned out the first "cheap" meter I used. Be careful not to tighten the positive wire on with the furnished nut to much, as it could cause ceramic to break and the bulb to lose life.
Rtom
Posted on Dec 14, 2008
We have a replacement bulb and I don't have a trap door to remove the old and install the new.
WARNING! Sim2 does does not recommend that you change the lamp, they recommend that you contact a local dealer for service. PROCEED WITH CAUTION!
If you still wish to proceed. This instruction is available at avsforum
http://www.avsforum.com/avs-vb/showthread.php?p=17983282
There are 2 recessed screws on the bottom near the front of the projector (really deep cavities). There are 2 on the backside of the unit. Remove all those and the top cover comes off. Inside you will see a fan held on by 3 screws (you will know it because there are 4 holes, but only 3 screws...that is normal). Remove those and take that fan module off. The lamp is then accessible.
Good luck! __________________
Jason C. Turk
Consultations, Installations and ISF Calibrations
585-671-2968
jason@avscience.com
Available for scheduled consultations...please contact the main office for details!
Mar 31, 2011 | SIM2 HT380 Grand Cinema DLP Projector...
How do you reset the lamp timer on a Sim2 Domino 60.
I would need to know the serial number of the unit.
You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
Mar 16, 2011 | SIM2 DOMINO D80 DLP Projector
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Need to replace NEC Lamp Unit in VT75LPE. Unit is bolted to ceiling in library and unable to be detached easily. What is procedure for replacing lamp?
Hi. You are most likely going to have to remove the projector *and* the projector mounting plate in order to access the lamp door. Mark the orientation of the projector mount plate with a marker and set aside. Remove the lamp door with a proper screwdriver. The PROJECTOR MUST BE COOL TO PROCEED!! The lamp will be secured, usually with 2 screws. Loosen these screws--new screws should come with the new lamp--already held in position. Using the hinged metal handle, pull the old lamp straight up and out of the projector. ( you might have to wiggle it and work it out steadily--its a precision fit) Take your time and *don't force* it! Carefully slide the new lamp into position, taking care that the power connector on the lamp assembly is properly seated. MAKE ABSOLUTELY SURE YOU DO NOT TOUCH ANY LAMP GLASS WITH YOUR FINGERS!!! If you do get finger prints on any glass surfaces, carefully wipe them off completely with a dry, soft cloth--DO NOT USE CLEANER!! This is critical to the life of the new lamp--finger oil attracts heat and will cause the new lamp to fail pre-maturely. Re-attach the lamp door--make sure you don't over-tighten any screws on lamp or door--they need to be firmly tight but not "gorilla" tight! lol Clean any dust filters thoroughly before re-attaching the mounting plate--you'll be glad you did! After re-mounting the projector, power it up and go into the menu in order to reset the lamp timer.--Hope I helped you!---Rick
Dec 30, 2009 | NEC (VT75LPE) Projector Lamp
Projector is brand new out of the box. Powers up displays Sim2 logo then lamp goes out power light starts to flash and turns off about 3 minutes later. Same thing every time it's turned on. Anyone had the...
the number of blinks determine the problem:
Environment Over Temperature- 1 long blink / 1 short blink
DMD Over Temperature- 1 long blink / 2 short blinks
Lamp Over Temperature- 1 long blink / 3 short blinks
Fan1 Locked- 1 long blink / 4 short blinks
Fan2 Locked- 2 long blinks / 2 short blinks
Fan3 Locked- 2 long blinks / 3 short blinks
Fan4 Locked- 2 long blinks / 4 short blinks
DMD Initial Fail- 3 long blinks / 1 short blink
Lamp Initial Fail- 3 long blinks / 2 short blinks
Ballast UART Error- 3 long blinks / 3 short blinks
Temperature Sensor Fail- 3 long blinks / 4 short blinks
Inter Lock Open- 4 long blinks / 1 short blink
any of these will result in lamp off and shutdown.
Aug 28, 2009 | SIM2 Domino D10 Home Theater Projector...
Projector fails to turn on
check your lamp. if it has bulges, black spots or fogging, replace it. otherwise, its your power supply/ballast.
Jul 15, 2009 | Office Equipment & Supplies
Sim2 Seleco DLP SDV 100 Projector only giving white screen dimly.
it's a resolution issue. make sure the projector matches the laptop's resolution. the projector has a 800x600 native and a 1024x768 max. and it's not digital.
Mar 02, 2009 | SIM2 SDV100 projector lamp Projector Lamp
Replacing the lamp in SIM2 ht-200
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
May 28, 2008 | SIM2 HT300 Multimedia Projector
Sim2 domino 20
Hi there
I checked the manual of your Sim2 , but they don't even mention the lamp in there.
You already have the front cover off , check if you can see any small screw around the lamp housing. They normally attach the lamp's housing with tiny screws to the rest of the unit.
Apr 24, 2008 | SIM2 Domino 20 Multimedia Projector
Projector not working
I have the same problem with a HT250, red power light on back of projector will not come on. But if you leave the projector plugged in and power switch on it will light after some time and the projector works as normal. Any suggestion please email lkrause0@fuse.net
Apr 22, 2008 | SIM2 Televison & Video
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
