Question about Whirlpool Duet GHW9150P Front Load Washer
How to clean my front load washer
I have a whirlpool duet Model # GHW915OPW1 i was wondering how do i run the cleaning cycle with the bleach.
  • 85 Answers
There is a product out which cleans interior of wash tub called affresh which works better that bleach which could be purchased at leows or home depot for about $7 for 3 tabs follow direction on package. remember use he type soap only and you only need 1 oz of soap per load
Posted on Dec 14, 2008
Towels have bad order
run it through a cycle to clean it with clorox bleach, make sure there are no clothes in it ;)... also your washer has a clean washer cycle.
Jul 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet was purchased December 2009 and lately has a strong odor. Does this front loader have a filter we can clean? Please advise how to get rid of this ongoing odor.
There is no filter but you might want to remove the bottom front cover and clean out the sump filter(a large white thumb screw attached to pump) turn to the left. After cleaning this out get a product called Affresh available at grocery and other stores. Put your unit on a clean cycle. If you can't find affresh try a cup of bleach and run that through a clean cycle. Another tip leave your door open when not in use
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Mold smell comming from duet washer
Hi
Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. You can also try using 1/2 a cup of Washing Soda or 4 cups of baking soda Crystals and run the machine with no clothes in it. This would remove all the debris, lint & mold growth from the drain pump and drain filter. This would clean the mold from the door seal as well. Hope this helps... Please post back if you need more information.
Daniel
Nov 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sometimes before washinging cycle complete I get an F9 code
Is it still spining and what else is it doing,Have you sanitized or cleaned washer use 1/4cup of clorox bleach (he) run through wash cycle no clothes. see what this does
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
Feb 11, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Duet steam washer -- light for washer cleaning
Affresh
Washer Magic
Tide washer cleaner
Bleach
All in order of what is best for cleaning your washer
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cleaning the washer, since if door left closed, clothes, smell like mildew, know there is a solution.....lost my book and have done in the past
Run the machine thru a normal or quick wash cycle adding only bleach, but before starting clean out around the door bellows by wiping with bleach on a rag. This works quite sufficiently for most folks. If on a septic system you can also substitue bleach for "pure white vinegar" hope that helps good luck
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in whirlpool duet washer
Hi, Go to you local appliance store and they should carry a product for this issue. Most front load washers are having the same issue.
I hope this helps you.
Vic
Jun 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front door gasket whirlpool duet washer
before replacing run a empty load with alot of bleach in it and then clean boot with a mold cleaner like kitchen cleaner w/bleach replacing the boot isnt something you want to do unless you have to do it (not easy) and the cost of the boot if you need any more help let me know and i will guide you thru the process of the boot
bill
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CLEANING OUT CAT DANDER ETC FROM WASHER
Quenie, vinegar will not harm your washer at all. Place it in the detergent side of your dispenser and run a Hot wash cycle. Don't mix chemicals, though... if you choose to clean your machine with bleach, for instance, don't use additional cleaners along with it. Vinegar only, bleach only... you get the point.
You may want to run a "water only" Hot wash cycle with bleach (no clothing/towels) after your Son has finished his laundry. This may help alleviate your allergy problem.
For regular maintenance on your washer, you ought to try something like this. It'll keep your washer smelling great.
Nov 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
358 people viewed this question
Dan Webster
Dan Webster
Sal De
