Question about Hitachi 46F510 46" Projection HDTV
How do you adjust the lamps on a 46 projection hitachi , i cant seem to adjust the red lamp ,have a more of a green tint
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Can you explain what exactly problem in TV?
    Does TV show greenish picture?
  • 80 Answers
There are no lamps in this set, you have picture tubes, if the tubes don't line up, you need new convergence chips, this is the most common failure in all rear projection tv's, you might also have burnt open resistors next to the convergence chips. if you don't have good soldering skills then you must have a repairman fix this.
Posted on Sep 05, 2009
I have a hitachi 50vf820 with green tint to it
Its a DLP type set that uses a lamp for a light source.
With the color turned to zero stand back and examine the image.
If mostly all green or areas are green you may have a issue with the optical light engine--either damaged inside from the heat of the lamp or the portion that processes red, green, and blue information bad.
Jun 03, 2012 | Hitachi 50VF820 Projection TV
What causes the picture to have a green tint
there are 3 color cathode in your TV red,green,blue cathode.The red and blue cathode might not working in your set that is why you have a green screen. Open the back cover of your TV you can immediately see the 3 cathode lamp at the back. Clean the lamp first using a clean clothe. Power up you tv and see whether the 3 lamps are lit. If lamps do not light up,check the circuit board where this lamp is connected re-solder all the components in this lamp. There is also an individual screen adjustment for the lamps it is located at the front panel and labeled RGB screen...try this first and let me know how it goes..
Apr 16, 2011 | Zenith E44W46LCD 44" Rear Projection...
My Hitachi 46F500 TV will not adjust either manually or in magic focus has green lines across top of screen and some red tinting in the picture this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
Hitachi 50c20 replaced lamp color is green
Go to menu then color ,Tint adjust the tint if that does not clear picture then you have Bad Lighht Engine Encompass parts Distribution might have it go to their website and type in your model number 1-800-638-3328
I always look for Parts on Ebay find better deals their sometimes.
UED might have it also 1-800-648-6657
Jul 16, 2010 | Hitachi Televison & Video
Green screen
inside the light engine there is a red a green and a blue glass color filter.The heat from the lamp causes the color to burn off the glass.You need new filters .One is red one is blue and one is green.The lcd itself doesnt make the color,it is a black and white device.The colr comes from light shining through colored glass
Nov 11, 2009 | Hitachi 42V715 Rear Projection Television
Too much red
have you got a convergence tool on your menu if so you can adjust by using your up and down or left and right buttons.
May 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Feb 12, 2007 | Toshiba 46HM95 46" HDTV
Hitachi 46F510 46" Projection HDTV Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
