Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Bad picture i own a samsung le32r7bd lcd tv , the whites go fuzzy and the blacks go fuzzy green . ican solve the problem by slapping the back of the tv, but it always returns
SOURCE: Black/Dark Colors Fuzzy w/Red Pixel Outline
I have the same problem too....
Posted on Jun 19, 2008
  • 5 Answers
SOURCE: Samsung LCD TV Image Retention...I Think
Sounds like a defective set. I have the same TV and don't have this problem. It's a long shot, but one thing you could try is turning on "Game Mode" which is designed for fast moving action.
Posted on Jul 15, 2008
SOURCE: Samsung 40 inch LCD LNS4092D No Picture
I had a very similar problem, TV was 1 day old! Samsung engineer came out and replaced the motherboard - all sorted now.
Posted on Mar 01, 2009
xCAUSALITYx
  • 210 Answers
SOURCE: vertical black lines in samsung lcd tv
Hardware related, needs an engineer as not a simple fix.
Thanks
Posted on Sep 05, 2009
milkburp
  • 416 Answers
SOURCE: MY SAMSUNG LN52A650 LCD IT WILL TAKE 3 TO 5
Your power supply has some bad capacitors. They are easy to change if you have a soldering iron and can make a trip to radio shack. You need to take the back off the TV and locate the power supply. It is the tan board to the left... the power cord connector runs to it. There is a connector in the top right hand corner of this board. Once you locate it, look at the capacitors (look like plastic wrapped cans) near there. You will see some of them with swollen tops. These need replaced. Identify the value (1000uf or 2200uf). Go to radio shack and purchase a few of them in the 16v - 25v range (16v fit better). Replace them and put it back together. Works like a charm. I have a basic tutorial on soldering... the demonstration was actually on a Samsung power supply, changing these caps. You can check it out if you like on my tips & tricks. I hope this helps.
Posted on Mar 21, 2010
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
White screen
"White screen" on Samsung LED TV - Forums - CNET
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
EASY Common BLANK SCREEN FIX FOR LCD SERVICE ...
? 4:42
https://www.youtube.com/watch?v=SARGnOExL8c
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
I have a samsung lcd tv that powers on has sound but the picture is fuzzy and has no colour . What would be the component that needs replacing for this ??
Hello. Before you start replacing parts, make sure your connections are correct. It sounds like you have connected a composite source to a component input. Composite is three RCA plugs, a yellow for all of the video, and a red and white for audio left and right channels. Component is five RCA cables, green, red and blue for video, and red and white for audio. if composite is connected to a component input, the picture will be black and white with squiggly lines all through it.
Mar 31, 2015 | Samsung LN40A550 LCD TV
Samsung LCD cm07 good then bad picture, powers off and on
well this could be a power supply issue try this web site they could have the part www.discount-merchant.com
Ness
Jan 05, 2010 | Samsung HLN5065W 50" Rear Projection...
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
46" LCD TV
Have you try the other inputs?
I would suggest to try all the other inputs and if you're still getting a black and white picture then that would mean a defective main board. If your TV is less then a year old, still cover under manufacturers warranty.
Let me know if you need further assistance.
Jan 02, 2009 | Samsung LN32A550 32 in. LCD TV
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
73 people viewed this question
Henry  Thomas
Henry Thomas
