Question about JVC Cybercam GR-D90 Mini DV Digital Camcorder
GR-D90 will no longer record onto memory card
I have a GR-D90 and I can't get it to record onto a memory card. Going through "set-up" by pressing the wheel, it won't even give me the option to do so. Yes, the button is set on "DSC" and not "VIDEO". I tried to place a new 8GB SDHC card in it and the screen gives me a "card error". I then placed a regular SD card in it after that, and the "card error" disappeared, but no luck recording.
In the past, I might have removed a card while the camera was powered on. Could that me the problem? If so, how do I resolve it? Much thanks in advance for a quick reply; for it is the x-mas season to record our toddler. Jason
  • 1,879 Answers
CHECK CARD’S WRITE PROTECTION SWITCH.
Remove the memory card once and insert it again. Repeat these procedures until no indication appears.
Posted on Dec 14, 2008
  • 435 Answers
Removing when the camera is on, could be causing this problem...As you should first turn the camera off, then remove the memory card... :)
Also, let me check for any other solutions for your problem...
Thank you
    Master:
  • 479 Answers
Remove the battery of the camera and reinsert it and also check out if the battery is very old then replace it and then check out.it could also happen that the caRD is
  • JVC Master
  • 13,433 Answers
Hey,
The card error comes most likely becouse the card is not formated properly, there should be a format card option in the menus somewhere.
Also try to restore the camera to default settings it should restore it the way it was.
I'll look into it, Thanks, report back how this goes.
How to operate gr-d70k digital video camera?do i need recording tape even they have a memory card?and how to change the language from japanese to english
You will need a Mini DV tape to record videos. The memory card can only record snapshots. When you rotate the LCD panel away from the body of the camera, you will see some controls. On the left of the second row, there is a switch. Set it to Memory to record to the memory card. Set the switch to Video to record to the tape.
I'm not sure how to change the language. There are no language options for the GR-D70.
The manual for the JVC GR-D70 is available here: http://www.jvc.co.uk/files/instruction_manual/lyt1145-001a.pdf . I believe that the GR-D70K will work the same way.
I hope this helps.
Nov 15, 2013 | Cameras
I have a GR_D90 Camcorder- it will not read the memory card-New 16gig-SD card what shall I do? will the recorder still work if the card does not? where can I get replacement CD-rom for this camcorder?
According to the manual, the GR-D90 works with MMC or SD cards. Your new 16GB card is actually an SDHC (Secure Digital High Capacity) card. While SDHC cards will fit into an SD slot, they are electronically incompatible and will not work. SD cards max out at 2GB in size.
Mar 19, 2011 | JVC Everio GZ-MG360 HDD Camcorder
How can I video with the memory chip in my camera GR-DX307
Insert memory card, set to camera mode and set to memory, then hit the E-MAIL/INFO button and then you can press rec start/stop button as if your are recording on tape. It is a low quality video(email clip). To play, slide the power button to PLAY and press select(beside E-MAIL Button) and choose E-MAIL CLIP. Thats it. Good Luck
Mar 09, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Nikon D90- no images in folder
Do you have a memory card in the camera? There is a setting in the camera that will allow the shutter to release if there is no card, however no picture is recorded.
Jun 12, 2009 | Nikon D90 Body Only Digital Camera
I have a used GR-D270U JVC camcorder, can't record w/it?
You can get a free membership on this site and download a manual, where, on page 18 of the pdf
document you will discover that the recording button is at the rear of the camera, at the top right hand
corner of the battery and at the lower right hand corner of the viewfinder, you can get tapes anywhere, even drugstores, and simply select memory card recording to record to your chip.
Apr 10, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Want t orecord directly to an SD card
That card can only be used for pictures - you need to buy tapes :)
Apr 05, 2008 | JVC GR-D770 Camcorder
Problems recording onto memory card with JVC GR-D70
DUDE u can only take some stills in the memory mode. no vedio recording is available in memory mode. Thats not a problem DUDE. i got the same model.
mail me mohammedshafit@rediffmail.com
Dec 28, 2007 | JVC Cybercam GR-D70 Mini DV Digital...
How do i put a tape recording onto the pc?
Unless the video is stored on the memory card you cant transfer it directly, you need a video capture device, it is an attachment to your Computer that manages the transfer of taped video copies to digital...
Dec 09, 2007 | JVC GR-D60 Mini DV Digital Camcorder
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
JVC Cybercam GR-D90 Mini DV Digital Camcorder Logo
143 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
