Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima VTD20/VTD00
My washing machine will not operate longer than 60 seconds before it starts flashing F18 on the screen. It starts to fill with water but cuts out and drains as soon as the fault comes on. Have you any idea what this fault could be please? Toffee
  • jan lewis Mar 29, 2007
    The water didnt fill for long before it cut out, so I dont think it was a problem with overfilling. It is now working fine, but I'm still wary about it going again.
Had the same problem. Take the back off (after the usual precautions, unplug, turn water stopcocks to off). Look at the bottom of the motor, there are 2 thin brown wires loosely held together with a short white protective tubing. It is likely that one or both of these wires have come loose from a Bakelite type connector going into the motor, near where the belt rotates. This is the feedback tachometer to the control unit. Basically it tells the machine how fast the motor is going. When the machine starts to fill, the motor turns a couple of times, no feedback therefore the control unit stops the cycle and drains it. I tried to solder the wires back onto the connector but when I refitted the motor the joints broke again (maybe I was too rough but the connector isn?t designed for re-soldering). A replacement motor did the trick ? but check out Hotpoint?s service plan, it lasts for a year and they will replace the motor under that plan. If a different fault develops they will replace the machine for a new one. Hope mine breaks within the year?good luck.
Posted on May 31, 2007
    President:
  • 1,462 Answers
Possibly it is overfilling - the pressurestat has a overfill function which turns on the drain pump. how high does the water level get when this happens?
Posted on Mar 29, 2007
SOURCE:
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima vtd20
Mar 11, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
123 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
