Question about SanDisk Sansa e260 MP3 Player
Its a white screen, and my computer cannot reconize it anymore, and on the white screen, its a bunch of blue lines running donw it...wont turn off or nothing... i use windows xp to format my sansa sandisk model e260 and now nothing show on the screen blank
  • AnubisXxX Dec 13, 2008
    Same thing
  • crbbp6 Apr 15, 2009
    I have the same problem, and the sansa updater doesn't recognize that the player is connected.
  • 43 Answers
Connect it to the comuter then get sansa updater and reinstall the firmware on the sansa
Posted on Dec 13, 2008
Blue green red line middle screen
REFIX LCD VGA CABLE NOW CHECK PROBLUM SAME SO LCD IS FAULTY .
Aug 26, 2017 | Acer Computers & Internet
Get the blue and white lines of my screen
you can go to the service center may be your display is not working properly
Sep 13, 2013 | Fujifilm Finepix Hs30exr black Digital...
Very horizontal faint white lines running down the screen
hi,
check if the line appears in BIOS...dont worry when i say BIOS...not sure how to check...turn the system off...restart the system and keep tapping the F2 key...you would get a Blue screen...check if the lines appear on this screen...if it appears...it could either be b'cause the display driver has gone wrong or the system might have a physical damage.....if the lines does not occur on this screen....it is a manufacturing defect...please contact the manufacturer and report the issue for solution.......
regards
Rocky
Jan 12, 2010 | Acer AL1717 17" LCD Monitor
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
It wont Work :(
I would try to get into the recovery menu and see if you can run a clean up first (a clean up will not erase anything on the player).
To access the recovery menu
1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole underneath your player, beside the data/power connector. Keep on holding the Play/Pause button while you release the Reset button. The Rescue Mode screen will then appear.
4. After the recovery mode has started, release the Play/Pause button.
Again if you can get into this menu, try a clean up first to see if that resolves the problem. Clean up should be the first option in the menu.
Apr 08, 2009 | Creative Labs ZEN SLEEK MP3 Player
Screen
your LCD goes damage left side of lcd there is mosfet ic's it was stick out and it can not repairable
so change your lcd from service center
Jan 20, 2009 | Mirus (SITL51C410) Notebook
Software
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 13, 2008 | SanDisk Sansa e260 MP3 Player
My Sansa was working, the i disconnect and now its a white screen
-Tha Mp3 Doctor
Dec 08, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e200 got soda or something on it, screen wont ligt up, and the computer dosent reconize it when plugged in, do I need a whole new screen?
You need more than a screen - you need a whole new player. The liquid, even when dried, will not allow your player to function properly anymore. sorry.
Jul 05, 2008 | Audio Players & Recorders
Black screen
people have been having a lot of trouble with rhapsody i think you could have a bug in your system.
Oct 25, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
548 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
