Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima vtd20
My washing machine will not operate for more than a minute before a fault flashes up on the screen saying F18. Have you any idea what this could be indicating please?
Had the same problem. Take the back off (after the usual precautions, unplug, turn water stopcocks to off). Look at the bottom of the motor, there are 2 thin brown wires loosely held together with a short white protective tubing. It is likely that one or both of these wires have come loose from a Bakelite type connector going into the motor, near where the belt rotates. This is the feedback tachometer to the control unit. Basically it tells the machine how fast the motor is going. When the machine starts to fill, the motor turns a couple of times, no feedback therefore the control unit stops the cycle and drains it. I tried to solder the wires back onto the connector but when I refitted the motor the joints broke again (maybe I was too rough but the connector isn?t designed for re-soldering). A replacement motor did the trick ? but check out Hotpoint?s service plan, it lasts for a year and they will replace the motor under that plan. If a different fault develops they will replace the machine for a new one. Hope mine breaks within the year?good luck.
Posted on May 31, 2007
I have a hotpoint ultima wf860 it was all fine then all of a sudden its saying the error code f-18 how can I fix this please as I havent enough money for a newone yet. many thanks x
Hi, The link below is a user manual for a hotpoint ultima wf860 and below that are the error codes, I wish you all the best......CHEERS...
file:///C:/Users/Steve/Desktop/4992cbf9-f956-4127-bdab-caa958e02377.pdf <---"NEED TO COPY AND PASTE"
Hotpoint Washer Error CodesF01 - Electronic circuit board fault
F02 - Motor circuit fault
F03 - Temperature sensing fault
F05 - Waste pipe blockage or pump issue
F06 - Door lock fault
F07 - Electronic circuit board fault / heating circuit fault
F08 - Heater fault
F09 - Software fault
F11 - Pump circuit fault
F12 - Electronic control fault
F13 - Dryer temperature sensing fault (washer dryers only)
F15 - Heater control fault (washing machines and washer dryers)
F16 - Drum lock position sensor fault (top loading machines only)
F18 - Internal data error
F19 - Fan motor or heating fault (washer dryers only)
Apr 01, 2016 | Hotpoint Washing Machines
Hotpoint Ultima WD865. Showing Error Code F-18. Please advise.
hi, i turned on my wd865 machine and it starts fine and sounds the same but its displayinf f 18. but it doesnt continue the wash in the usual way . what does f18 mean ? please help :)
Mar 21, 2010 | Hotpoint Washing Machines
Hotpoint Ultima Wt761 is displaying F-08 what can I do any ideas please
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
Oct 25, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
Wf860
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima VTD20/VTD00
possibly it is overfilling - the pressurestat has a overfill function which turns on the drain pump. how high does the water level get when this happens?
Mar 25, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
128 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
