Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Damaged power supply plug for Zip Connect i Tower
Model # SI333 i Tower
AC Adapter Model CP2420
  • 3 more comments
  • melissacia Jan 07, 2009
    The three metal prong unit on this adaptor is off. It seems like a prong inside melted. Is there anywhere we can send it to be fixed or purchase that part of the adaptor? The itower is useless without it.
  • Anonymous Feb 22, 2009
    mine has a four prong power source but it also came apart. Like you said, it's useless without the cord
  • jet2erboy Feb 22, 2009
    what kind of cord is it? i have the itower SI333 but i lost the power cord. anyone know where i can buy one? radioshack?
    I know sharper image is out of business but i dont know if the power cord is universal or something
  • tkeith_0509 Mar 08, 2009
    I also have a problem with my power supply cord. Somehow, after just a couple of months use there seems to be some kind of short. I have looked on Ebay to no resolve. I just need a new cord without having to buy an entire I-tower.
  • Anonymous Mar 09, 2009
    ahhh! i am searching for the same solution! mine needs a 4-pronged power cord...
It's +24DC and -24VDC.
the connector is a 4-pin DIN but hard to locate. Older laptops used the same connector. I'm in the middle of fixing two for some local folks here as well, and I can't locate them on Mouser.com. But I do have two older laptops that I may just use the cord from and repair the SI333 iTower supply for them.
Tim
Posted on May 25, 2009
  • 2 more comments
  • tnorris0143 May 25, 2009
    connector is a KYCON.
    part number KPPX-CM-4P (aka 806-KPPX-4P via Mouser.com)
    I'm ordering a few to fix the ones that were brought to me for repair.
    Tim
  • tnorris0143 May 26, 2009
    sry for some reason I'm getting a mix of 2 items ..
    I didn't reply to the ionic breeze question, I replied to the iTower SI333 power "brick" problem .. this speaker system allows an iPod to be plugged in at the top of the "tower" for playback.
    Tim
  • Mackenzie Aug 28, 2012
    HELP!!!
    Add a CommentHello. I have a itower and am looking to find out how to fix the four prong metal piece. Is the 806-KPPX-4P the cord that I can just plug in? If not where are you located so that it can be fixed? And about how much will it cost?
I may be able to help you but I need the following:
1. The output specs from the back of the box between the power cord and the speaker connector (ie: Output: 17VDC 3.5A)
or
2. A digital picture of the back of the converter box
Posted on Apr 24, 2009
My Brookstone PureIon Advanced air filter is stuck in TURBO mode and I cannot get it to slow down! how do I UN-stick it?
Sounds like the control is damaged. You could try calling Brookstone service and see what they say (they have a one-year warranty). Number is 1-800-292-9819.
Aug 12, 2016 | Brookstone Air Purifiers
Ionic breeze gp
cheak main power unit see if u can get one from radio shack start there do u leave it on 24 7 fan puts on a heavey load on power trasformers blows them easy
Feb 05, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
I have a tower fan 42" that produces no air. I have checked the fuse (ok), I have connected to black wires that were way from their harness....still no air
apparently nobody gives a hoot will throw the piece of **** in garbage and never buy a product from this company ever again.
its not a profanity it is a bodily function
Nov 01, 2014 | Bionaire BT440RCU Remote Control Tower...
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
What happens having one broken wire?
Not trying to be funny, but it depends on the wire, if your air purifier is still running or not, whether you have lost hi/low settings etc. Or is your plug wire and you lost the internal ground wire. Attached link you are able to download user manual. Need to be more detailed, color of wire, location of break. Hope this helps, or provide make model, and other details. PEACE
http://www.oreck.com/userguides/global-user-guide.html
Redirect Notice
Jun 07, 2014 | Oreck XL® Tower Air Purifier
How do I Open the Vorando Tower Fan to clean
Use a flashlight to look through the vents on the front. You should see screws.
Mar 24, 2014 | Frontgate Vornado Tower Circulator Fan -...
I have an ecoquest flair that the fan won't run.
bad capacitor in the control head..if you run it at full speed, you may be able to run it hardwired(but it becomes a safety issue) may need it replaced..
Jan 18, 2014 | Ecoquest Fresh Air Air Purifier
Where can I get replacement wires for an oreck truman cell? Seems silly to spend 200 dollars when the only thing wrong is four 29 cent wires does it not?
Here is a link to where you may can find what you need. You will need to have the correct model number (not just XL Tower Air Purifier) , to find your mode.
http://www.ereplacementparts.com/oreck-air-purifier-parts-c-130239_130321.html
Hope this helps you find the wiring you need. Thanks for choosing FixYa.
Sep 19, 2011 | Oreck XL® Tower Air Purifier
I cleaned my oreck xl tower air cleaner and the red light won't go out? Non of the wires are broke on the truman cell
This is a common problem with the Air Towers. what needs to be replaced is your power supply. If you turn the tower on silence, and you listen very closely to the base of the tower you should hear like a little zapping or buzzing noise. the only way to get it replaced is to take it to an Authorized Oreck dealer and as long as your machine is still under warranty, 5 years from the purchase date, it will be free of charge.
also when ever you wash the cell you want to make sure its completely dry. let it sit out for at least 12 hours. 24 hour is ideal.
Sep 10, 2011 | Oreck XL® Tower Air Purifier
It just stopped, I have never liked it. Can I please return it, or get a credit for it? Model #al 1100.
If you have the reciept for it you can return it to get your money back but you will haveto take it to place of purchase.
Jul 03, 2010 | Tower Air Innovations Ionic Air Purifier...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
1,853 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
