Question about Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451
Makita lithium ion 18 v battery wont charge
This is the second battery battery that wont charge both under a year old
onlt one of 3 now charging any ideas ?
  • Anonymous Mar 31, 2014
    cherger flashes
    New Friend:
Do not keep her on cold place. sorry but you have to buy new one again :/ take a look on amazon or something:
Amazon com Makita 18 battery
Posted on Dec 05, 2014
This normaly happens when the battery has been kept in cold conditions . keep your batteries indoors try sitting them on a radiator for a short period and they should take a charge . cold weather effects the cells in lithium ion batteries .
Posted on Feb 09, 2009
  • 9 Answers
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, the fusible link will blow (kind of like a fuse)
To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again.
If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering.
Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it!
Hope that helps.
Matt Binns
GiantGlobes.com
If your battery reads well below 10-12volts….
Try charging the battery with a car charger set on low (2 amps max) or a wall transformer from a phone or some such with a 12vdc output (make sure it is 12vdc not 12vac) You will need to know which of the charger wires is pos and neg, be careful not to short the battery as this will blow the fusible link. Connect + to + using jumper clips or stiff wire jammed into the battery contacts.
Once you get the battery over 10-12 volts the charger will normally accept the battery.
You can jump one good battery to the bad to do this, but in all cases watch out that the wires do not get hot, as this is a BAD sign, often a minute or two will be enough.
Of course you may have a dodgy charger, they are not robust at all.
The fans also ****, noisy and sometimes they quit, causing the charger to quit too
Matt Binns
GiantGlobes.com
Posted on Aug 18, 2009
  • Firedog91902 Nov 02, 2010
    Matt, I don't find the "bridge of metal with a hole" in the BL 1830 battery.
    I believe the cause of these failures is the protection circuitry disables the recharging ability if the battery drops below a certain thresh-hold voltage. My 2 failures were batteries that I didn't stop using when the tool’s rpm slowed down. There should be a way to reset the lock out, but I don't know how. Lesson to learn...stop using the battery when the tool slows.
    I have been able to get some use of these locked out batteries with the following method. Read the caution below!!
    1. Open the battery. Check that all of the 5 cell pairs are reasonably matched in voltage; open circuit and during charge and discharge. If not, replace the "dead" pair(s) and then charge or discharge the others individually until the voltages approximately match.
    2. With the cells removed, drill 5 holes on each side of the battery case directly over the ends of each cell. Tread the holes with a tap. Remove the paper insulator from the cell ends and assemble the battery. The holes let you monitor separately each cell pair’s voltage. Carefully screwing in a machine screw to just touch the cell ends allows charging and discharging the cell pairs individually.
    3. Use a 19.3V laptop charger connected directly to the plus/minus of the battery. If the cells are balanced, this applies 3.86v/cell and results in ~1 amp charge for a used battery which tapers down to no current after ~ 6 hours. I believe is a safe float charge voltage for healthy cells but I would never leave it connected continuously. It will never charge the battery as completely as the original charger which pumps a constant current at up to 4.2v/cell, then tapers down and finally shuts off.
    Caution, caution, caution. The OEM charger has many of safeguard built in to it.
    This method removes all protection! There could be serious problems if for example, 1 cell fails due to an internal short. The other cells would divide the 19.3 volts and be overcharged if left connected for a long period. They could explode. Always check the voltage of the individual cells before charging and monitor them regularly. If you skip drilling the holes for monitoring voltages, or don’t check voltages before each charge, you will eventually get in to some serious trouble.
  • Tom Hamilton Jul 05, 2012
    VERY DANGEROUS WITH LITHIUM.
    Problem Solver:
  • 7 Answers
I have just had a similar issue I left the drill unused for a period and when i placed it in the charger the charger showed the battery as charged after about 15 seconds.
Following a internet search I found a site that suggested for a simlar problem with a camera jump starting the low battery with a 9 v battery. I had a spare 18v from the drill so placed a contact from + to + and - to- and held for about 2 mins. I then placed the battery back in the charger and it started charging. Running the battery down as we speak to recharge again well worth a try. If you dont have a spare maybe the 9 v would work
Posted on Aug 05, 2012
  • 1 more comment
  • Muhammad Abdul Hadi Aug 12, 2013
    HI Ian,
    Did you use one of the rectangular 9V battery?
  • ian_thomason
    ian_thomason Aug 14, 2013
    I used my spare 18v and used paper clips as jumpers, either wedging them in or using electrical tape, for the positive I used stripped wire as the clip was not long enough. whether there is enough power in 9v I dont know, but well worth a try, mine is still charging without any issues
My makita batteries nolonger charge
Lithium batteries do have a life span determined by how many times the battery is discharged and recharged and how hard it is worked on the tool. Batteries get hot while charging and discharging and heat is what ages batteries. Lithium batteries, depending on usage, will last from one to three years. I've seen some last five years but that's rare. They also have numerous cells and a circuit board that can go bad and kill the battery. Chargers are designed to check the battery's condition and won't charge a battery if it detects something wrong. If your battery is under one year old, it's covered by the warranty. If it's over, you'll have to buy a new battery.
Mar 03, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
I have 2 DeWalt Lithium-ion batteries Apprx. 4 years old, charged 3 times...won't charge now
Either bad batteries or a bad charger. You can use a multimeter to test for DC voltage output in the charger.
May 03, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Hi my makita 18v impact driver seems to be getting alot weaker throughout the years, still works but no enough torqe
Lithium batteries have a limited lifespan, typically 3 or 4 years, and their capacity between charges decreases over the years.
To extend the lifetime of a battery it should be run completely flat after every few charges rather than topping it up. New batteries need to be charged several times and run flat under normal use before they gain their full capacity.
Apr 18, 2011 | Makita 18V LXT Lithium - Ion Cordless...
Hi both red and green lights are flashing and it wont charge battery bl1830 lith ion
If both lights are flashing it means the battery is defective so it won't charge it. By defective it could mean the battery is just worn out or there may be a short in the battery. If the battery is under warranty you can get it replaced at a Makita Service Center, if not you have to buy a new battery.
Sep 13, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
The Makita BL1815 battery will not charge, lights flash red/green, indicating bad battery. I replaced one open cell with known good cell, charger still reads bad battery although I can charge from an...
tried it a few times. got the charge up to around 13.9 and it still wont charge. i dont understand, because the battery isnt that old to begin with. thanks for the suggestion.
Dec 16, 2009 | Makita BL1815-2 18 Volt 1.5 Ah Compact...
My 18 volt makita battery wont charge and it is less than a year old. Do you know y? Can i fix it?
Those batterys need to be on the charger if they are not in the tool. I would try to get the store to exchange the entire set for a new one. If that fails ebay sells batterys pretty cheap.
Feb 25, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
My makita 18v 2.0 battery won't keep a charge
How old is the battery?
They have a service life and require replacing after they no longer hold a charge. This could be 2 years or 8 years depending on how often it is used and how regularly it is charged etc.
If it is a new battery, then take it back as it could be defective.
Possibly could also be the charger but you could verify that by charging a different battery and seeing if it charges that second battery ok, or not.
Jul 04, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita Tools 18V 1/2" Lxt Lithium - Ion Hammer Driver - Drill Kit - BHP451 Logo
24,725 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
