Question about GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player
CD player skipping
Having a problem with the CD player skipping. The CD will play about 10-15 seconds of the first track, then starts skipping. If I skip ahead to the next song, or even 10 songs into the disc, it will say "nd" (no disc) and won't play anything. It happens on every cd I try. I've tried a CD lens cleaner (GE Laser Lens cleaner from walmart) and it hasn't helped. Any ideas?? Thanks in advance.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 44 Answers
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Posted on Jul 23, 2012
  • kellypearl Jul 24, 2012
    Not a bad thought - however I've had it mounted for 2+ years and it just barely started skipping. Think that would make a difference?
SOURCE:
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
May 19, 2011 | NAD C545BEE
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
Jan 14, 2010 | Alpine CDM-7874 CD Player
CD changer skips on bumps
There are two ways either the 90* or the 180*. If your having problems like skipping I'd suggest finding a place at the center of the car where there is less shock for the unit, like under your seat. I know changers have this 6 seconds or more memory so in case it skips, the first 6 sec ahead of the song is stored and play it to avoid the skip.
Oct 09, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Cd player showing error 43
Still under warranty?... check that.
Mar 24, 2009 | 2008 Hyundai Elantra
Denon cd player skipping on some track/cds
This could be a possible worn laser pick-up problem.
Regards.
http://www.audiovisualservices.info/
Nov 28, 2008 | Denon Dns1000 Table Top CD Player CD...
Player stuck in scan mode
Hi...
Unplug it from the wall...give it a couple minutes. Try playing a CD again (using manual controls) If that works , your remote might be the issue.
If you bought the thing new you paid good $$ for it.
It's worth having it looked at by a Pro.
Oct 22, 2007 | NAD C521 CD Player
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
CD Player Acting Up
some cd players have a feature that is called intro. it plays typically the first 4 to 10 seconds of a song & goes to the next track. it does this to every song on the cd. see if intro is on your display or if it's turned on in the menu. i hope it works. good luck.
Jan 04, 2007 | Aiwa XP-R230 Personal CD Player
GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player Logo
655 people viewed this question
Top GE Audio Players & Recorders Experts
Racki123
Level 1 Expert
Rob Hill
Rob Hill
Joaquim Martins
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
