Question about Uniden GMR638-2 (7 Channels) 2-Way Radio
HOW DO YOU TURN IT ON
New batteries are in place, last used was four years ago batteries were removed when finished with use
    Problem Solver:
  • 4 Answers
Try pressing the button that has a circle with a lin going through it
Posted on Dec 14, 2008
My cordless black and decker bateries HPB18-OPE WILL NOT HOLD A CHARGE
These drills are cheaply made and are fairly cheap.
I asked the store where I bought mine and he said he would get me a new battery. He wanted thirty four dollars for the battery and I only paid forty bucks for the whole drill a year ago.
I learned something
I bought a Ryoby at 149 dollars and came with two batteries. I keep a battery plugged in all the time and switch them once every two or three weeks. I bought this one three years ago and it is working like it was three years ago. I just leave it plugged in all the time. The cheap B and D won't last very long.
Apr 12, 2015 | Drills
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
2005 lincoln aviator on fifth battery in nine years. Why?
Motorcraft Batteries?
In my Lincoln L/S, the first one lasted 3 1/2 years & was done under warranty
Second one lasted 5 years
Now that one failed two weeks ago at 20 months
In my case the battery is in the trunk & you can't find a battery with
a vent for that car & ford batteries are on odd size, just for their
design or group size,go figure
The Motorcraft Max is free for 3 years & pro rated for 100 months,
so not a bad deal.
IF you have a big enough battery tray & a basic looking battery,
try the NAPA Legend Batt 8465 750 CCA 65 BCI (group size)
They are from East Penn MFG in Penn & plants in other states & their own brand is DEKA in the private parts stores
What I like is that there are no caps on top & no leaking, just like
the old AC Delco I used for 40 years & got 7 to 9 years out of them
I have had a Napa in my 30 year old blazer for two year so far
The question,well I think it is part battery & part the load the electronics puts on the batteries
When I open the trunk & have only the trunk light on & with a
new or old battery, I only get 12.3 volts
I get the same thing on my scan tool data when I turn off the car
& then put the key on,yet all data is good KOEO or Engine Running.
Mar 22, 2014 | Lincoln Aviator Cars & Trucks
After a four day power outage, my APC BE325R buzzes continuously when started, even though nothing is plugged into it. Has the battery suddenly died, or does it require recharging? Its a very loud buzz -...
It is probably a bad battery. They usually don't last much longer than 2-3 years. You could try replacing the battery, but I would suggest just replacing the whole UPS with a new model.
Sep 08, 2011 | APC BE325 SURGE PROTECTOR + BATTERY...
I have a Craftsman mulcher model 315.370270. The green recharge light goes on but the battery charge level stays in the red. Do I need a new battery and if so where do I buy it?
I guess you've solved this by now, sounds like you need new batteries if the mower lacks power after trying to recharge. There are two sealed lead acid 12-volt batteries connected together on this mower to provide the 24 volts of power. These are the same batteries that are commonly used on rechargeable power wheelchairs and scooters. So you could find them at a Durable Medical Equipment company. The last two times I bought them, I got them from a DME company where I used to work. I also looked into buying them over the internet. Just make sure the replacement batteries are the same size and specs. You could burn out your on-board charger by continuing to charge batteries that are shot. I did this a few years ago with my 315.370270. Since then I have been charging the batteries with my portable Craftsman charger. The 12-volt batteries last about 3-5 years. I have had my mulcher since 1995 and have replaced the batteries about four times. This is the best mower I've ever owned. I'm going to retire it this year, if you're interested in it for spare parts.
Aug 27, 2011 | Craftsman Garden
My camera will not charge. It was purchased just short of a year ago, so here is no reason for the battery to be broken. It will not charge at all when the memory card is inserted and when it is, the...
Hi, It almost sounds like the battery won't hold a charge anymore which means you need a new battery. Since the camera isn't quite a year old yet I'd suggest contacting Nikon and seeing if they'll do anything for you before you buy a new battery.
May 12, 2011 | Nikon Coolpix S4000 Digital Camera
I have 2006 super glide I just picked up a teo months ago. I rode it for a few days. I was out on it last week in the heavy rain. When I went to start it yesterday it was dead. I put the battery...
The battery on most motocycles cant take much abuse.Most batteries on bikes with proper care last about three or four years.If the one you have is this age or older I would purchase a new one.Good Luck.
May 09, 2011 | 2006 Harley Davidson FXDI Dyna Super Glide
I have a Thinner glass/brass round bathroom scale and I cannot find the battery location. I purchased this about 10 years ago from Frontgate but they couldn't help me. Can you?
I have a 10 year old Thinner bathroom scales also. Apparently the manufacturer designed it to make battery replacement hard so you'd buy a new scales. To replace the battery, if your unit is similar to mine, turn it over, remove all the screws and separate the top and bottom. You'll see the glass window that shows the weight. It is held in place by four tabs that are slightly twisted. Straighten them, lift the glass assembly clear without straining the wires, and turn it over to reveal the round black battery case. It is secured by three small screws and clear epoxy. Remove the epoxy with a knife blade, remove the screws, and separate the two halves of the case on one side being careful not to separate the other side where there is a metal connection piece. Using the knife tip, remove the CR2032 battery and replace it with a new one (available at Radio Shack or similar stores). Reassemble in reverse order; no need to replace epoxy. My scales worked fine after that.
Jan 09, 2011 | Conair WW81 Weight Watchers Body...
Norelco 835rx unused for 10 yrs, worked 1st time, then not.
The battery pack is, likely bad and will need replaced. Batteries don't hold up well sitting around for 10 years. The stress of charging may have finished off the batteries completely. When the batteries short out internally, the shaver wont run from the cord either. Before ordering batteries you'll want to make sure the old ones have not corroded badly and ruined the circuit board. To check it out, remove the four screws on the back and remove the back cover. Lift out the circuit board and inspect it to make sure there are no burns.
If everything looks to be in good shape, installing a new battery pack will probably be all you need to do. You will fin the correct battery pack at shaveroulet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Apr 05, 2010 | Norelco Health & Beauty
Battery Problem for Nokia N81 8gb
I bought new nokia n 81 few weeks ago.its battery finishes very quickly.plz help me
Jul 06, 2009 | Nokia N81 Smartphone
Uniden GMR638-2 (7 Channels) 2-Way Radio Logo
42 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
