Question about Zoom X6 (5590) DSL Modem (55900003)
Centurytel modem, can i run 2 computer off the one modem
I have centurytel and want to add another computer, what can i do
  • Anonymous Jan 16, 2009
    I HAVE X6DSL MODEM AND WANT TO ADD ANOTHER COMPUTER I CAN USE WIRE.
  • 92 Answers
All ya got to do is get a CAT 5 cable and plug it into the router/modem and plug it into the ethernet port on the computer
Posted on Dec 17, 2008
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
Unable to get verizon westell modem/router to work
Try this:
Go to the interface through your browser: 192.168.1.1
Go to profile editor, if there is a profile listed, click edit. Then enter in your username under Account ID and then your password. Hit save, then OK.
Then hover over the configuration menu option, click on advanced WAN. It should look like the following attached screen shot to this message. If the VPI/VCI and Protocol are different, which they probably are, click the edit button. Make sure it matches exactly as it appears above. VPI=8, VCI=35, Protocol=PPPoE.
If you have any more questions or this did not fix your problem, just come back here and leave a comment - I'm happy to help.
Aug 04, 2009 | Westell Wirespeed VersaLink...
I have a zyxel p 600 modem and cannot get it to log into centurytel internet can you help?
If you can go to the link below, there is a live support chat option. I believe that with Centurytel, you will have to configure the modem with their help to make sure it connects as there are specific settings for autehntication of DSL.
http://centurytel.myway.com/
Jul 09, 2009 | Westell Wirespeed VersaLink...
Set to work with centurytel instead of bell south
Howdy - You may have a two fold problem here. First of all the Westell wireless modem/router 327w has the access IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. That problem solved...
Now, from what I understand, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with centurytel but I do not know if it will work. I use the Bellsouth 327W and it is GREAT. Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
May 29, 2009 | Westell Wirespeed VersaLink...
How To: USB hookup for computer while having ethernet hookup to Xbox 360.
USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
May 21, 2009 | Westell Wirespeed LiteLine 6100...
WESTELL WIRESPEED DSL MODEM B99-210014-03
Probably not - contact your DSL internet service and ask what modem they suggest.
Sep 26, 2008 | Westell Wirespeed LiteLine 6100...
DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
Trying to use SpeedStream 5100 with new DSL Provider
I have Centurytel myself, so maybe I can help:
A link to your Speedstream 5100 router:
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
And the typical setup for the westell 6100 that centurytel uses:
Centurytel will provide you with your username and password.
PPPoE Configuration:
VPI 8
VCI 35
Protocol: PPPoE
Hope this helps.
Jun 12, 2008 | Efficient Networks SpeedStream 5100 Modem
Zoom X6 (5590) DSL Modem (55900003) Logo
254 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
