Question about Bunn NHB Coffee Maker
Incredibly slow dripping coffee
This is a Bunn we've had for 9 months and used to fill up in three minutes, now it takes about 20 minutes.
The reservoir feels warm....maybe not as hot as it used to feel.
But it just takes forever to be done and ready to pour.
Thanks.
Terry
  • 125 Answers
Get out the spring that came with it and ramrod the tube
un screw the shower head and clean that first the ram out the tube then reolace the head
this pot is not heat sensative when brewing coffee, like most of the other types
also pour in a quart of white vinegar, followed by 4 or 5 pots of water
Posted on Dec 14, 2008
My Bunn coffee pot seems to pour out so quickly. The grounds come out the back and all over the counter and in the coffee.
I have had this happen when I used non bunn filters . perhaps they non bunn are too small thereby letting the water run over the top My bunn takes 3 minutes when it's clean to brew 12 cups .
Jan 12, 2015 | Bunn Coffee Makers & Espresso Machines
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
I have a commerical Bunn coffee maker. I ran vinegar to clean it out. It dripped very slow. Now, I get a 6 minute pot, the coffee is 180 degrees, but the coffee is very weak! What is up?
Coffee maker is not pre-heating the water.The brew cycle should take about two minutes, and the coffee should be 200°F when it comes out, that is why it's weak. To clarify, is it a commercial model, or a home model (like the one pictured)? Home models will have a 'vacation switch' on the side of the unit that needs to be on to get the water pre-heated properly.
Jan 19, 2011 | Bunn 10 Cup Home Coffee Brewer
My Bunn has a slow drip. Model GRX-B. Have cleaned the disc sprayer and pushed the spring up in the hole. What else can I do? It used to drip a lot faster.
How old is the machine? If you have cleaned it and delimed the machine and it still is dripping slow, the machine may need to be replaced. Please call service at 800-352-2866 with the model and date code.
Oct 06, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee starts dripping down before I can get the water all poured in and the pot on the warmer, causing a mess.
This is common with bunn coffee makers, if you are not fast enough, coffee starts dripping. The only solution I found is to use a water pitcher, first fill coffee pot to cup mark you are using, then pour into pitcher, put pot back on machine, then pour in water. You can mark a line on picture, so you know where to fill to each time.
Jul 15, 2010 | Bunn NHB Coffee Maker
Cleaning
The metal proble is use to clean out the water tubing. Remove your sprayhead and insert the metal rod up in the hole leaving out about 1-2 inches. Then simply twist and turn the rod about 5-6 times. This will remove any lime deposits. Then flush out with 2-3 decanters of water. You can obtain a new manual by calling customer service or going to the website-www.bunn.com going to @home, then products-click on your brewer-and then select use and care manual and you can print it out or view it online.
May 19, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee is in water is in nothing happens
You may not have enough water in the tank.
Follow these steps
1. With the coffee pot unplugged, fill your resevoir/tank until water begins pouring out of your sprayhead and brew basket.
2. Wait for the water to finish dripping then plug in your Bunn.
3. Let your Bunn warm up for at least 8 minutes.
4. Run a test cycle with clean water, remembering to use the water pitcher provided for this purpose, while leaving your empty pot on the burner beneath the brew basket.
5. If your cycle completed, and your coffee pot is filled to the desired level you are ready to make coffee.
Remember that these Bunn models have no water filter2_bing.gif installed, so, the cleaner the water the better tasting the coffee.
Jan 04, 2010 | Bunn VPR Coffee Maker
This is commercial and the water drips instead of flowing,took 20-30 min to make coffee, how can i clean?
Have you tried to brew without coffee to see how long it takes? If yes then use a pair of channel locke to remove sprayhead and then use the deliming sprding that came with your bunn and clean the brew line then try again, if you still get the ame result, the brewer needs to be descaled.
May 06, 2009 | Mr. Coffee Coffee Makers & Espresso...
Hot Water Valve Inop
good water pressure to machine but very little water from dispenser
May 14, 2008 | Bunn CDBCF 15 APS Coffee Maker
Bunn coffee drips slow
I had the same issue, poured in 8 and out came 6. Here's what I did to clean and fix.
1) Unplug the NHB
2) Remove accessories like the pot and basket
3) Bring NHB over to the sink
4) Snap off the entire top cover (not the swing lid) by starting at the front and lifting upward (the top cover is about 1/4" thick). The back of the top cover will pivot a bit and then pop off exposing the pour reservoir. Remove the flow stopper inside the pour reservoir by lifting it straight up.
5) Place the top cover and flow stopper aside.
6) Remove the brew diffuser (located underneath the top where the brew basket goes. Twist counterclockwise gently but forcefully enough to snap it past the lock tabs which hold it in place. You'll know that it you've done this correctly when it just falls out.
7) Still over the sink, tip the NHB in a fashion where the back side is facing upward and the brew side is facing down into the sink. You'll be holding the NHB horizontally by the top and bottom of the unit. This will allow any water in the tank to pour out the brew spout. Begin to tip the unit as if tipping upside down as this will allow any remaining water to drain out. If this does not work the brew spout hose may be clogged and you can just tip the unit entirely upside down to empty it from the fill hole in the pour reservoir.
8) Return the NHB to the upright position in the sink.
9) Using a scotch brite sponge and some baking soda, clean the inside of the pour reservoir and rinse.
10) Using the tool Bunn provided, clean out the brew spout hose which is located under the brew hat. This is the little hole where the water comes out. If you don't have the tool Bunn provided you could use something like a plastic tie-wrap. Don't use anything metal as the hose you're cleaning is made of plastic tube and could become punctured. Clean this hose for just a minute or two to ensure that there are no significant obstructions.
11) With the NHB upright in the sink, pour a slow stream of hot water from the faucet, about two cups, directly into the fill hole located in the pour reservoir.
12) Tip the unit horizontally, as in step 7, and place the tip of your finger over the pour reservoir fill hole covering it completely.
13) Shake the unit back and forth horizontally so the water in the tank splashes around and frees anything which may be built up in the tank. Some water may splash out of the brew spout hose.
14) Tip the unit as in step 7 to drain the tank water out.
15) Fill a 16 ounce glass with hot water and 2tbsp baking soda, mix and pour into the pour reservoir fill hole.
16) Repeat steps 13 and 14 once.
17) Repeat steps 11 through 14 three times.
18) Clean the pour reservoir cover, swing lid and flow stopper.
19) Put the flow stopper back in place.
20) Attach the top cover.
21) Clean the exterior of the NHB.
22) With the boil and warmer switches off, plug the NHB into the electrical outlet.
23) Turn the boil and warmer plate switches on.
24) Fill the NHB with one pot of cold water and close the swing lid. Wait one minute.
25) Fill the NHB with another pot of cold water. Place the pot on the warmer plate and close the swing lid. If water does not yet come out, fill with one more pot of water.
26) Allow water to drain from brew spout until it stops draining.
27) Empty pot.
28) Fill pot to 10 cup line and pour into the NHB. You should find that the NHB now delivers 10 cups back to the pot. Empty the pot.
29) Clean brew spout diffuser and replace back in the brew hat.
30) Clean the pot, pot lid and brew basket.
31) Wait ten minutes for the water in the tank to boil.
32) Brew your coffee as you normally would.
The only issue I experienced during this process was with the warmer plate switch. It appeared that the light in the switch blew although the warmer plate still warmed normally. Shortly after the water in the tank started boiling the warmer switch light started operating again.
Apr 05, 2008 | Bunn NHB Coffee Maker
Bunn NHB Coffee Maker Logo
576 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
