Question about Hansol 730E 17" CRT Monitor
Hi all.. i have a problem.
Hello Everyone . i have a problem whith monitor . when .. i push the button in the monitor . in screen . i see NO SIGNAL... or nehnume signal where is my problem :( .. sory but my leanguage english .is a bad little :S greetz ..
  • 624 Answers
No signal means the monitor is not detecting a signal from the video card. Can you give us a little history about what lead to the problem?
Posted on Mar 11, 2007
Hp g6 white screen
You can use an external monitor to test this laptop. If your laptop works good with an external monitor, your laptop screen is dying and need to be replaced.
Mar 10, 2014 | Computers & Internet
I get a Red E1 and a green F5
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
GENE
Sep 05, 2011 | Whirlpool Ovens
Hi I ve got a audi A4 1997 and haf model. I ve got a problem whith the radio. I used to push the code when I the power went out whith 'Scan' and 'RDS' bottons as I know but doesnt works yet. Starts whith...
IMPORTANT NOTE:
You must have the security anti-theft code for your Audi radio from the car manufacturer, or from an Audi dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of programming for 1997 Audi A4 radio is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Apr 17, 2011 | 1996 Audi A4
Hello I have a samsung sync master 732n monitor. The power button just blinks but the monitor doesn't turn on it's properly plugged in to my computer. This has happened quit a few times already. When...
Hi your monitor is working ok but your pc display is the problem.
1.-take out the Memory and clean with eraser the gold part of the memory and your problem will be finish .
if still same means maybe your video card or board .
if your board have a video card build in take your video card and use only built in video
last press the keyboard Num Lock and look if ther is a light green
Nov 03, 2010 | Samsung Computers & Internet
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
Stuck on forgien languages.
push menu button once
push > button 4 times
push > button 3 times
push menu button once (now you are in the language selection screen)
push > button untill english is chosen
push menu button
now push far left button (has a monitor pic on it
Now you are back in english enjoy
bcmalloy
Apr 29, 2009 | ASUS VW222U Monitor
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Need to reset display settings
Hi
Take a look at the keyboard and find the FN button on the bottom left. (The letters FN are in blue)
Now look at the F keys at the top of keyboard and find one that has either a couple of monitor symbols or the letters CRT/LCD - again in blue
Holding down the FN key and press the other key, this should change screens between the external and internal monitors. Don't expect an instant change - it sometimes takes a couple of seconds to do the job.
If that does not work then attach another external monitor, right click on the screen and select properties. Now select the far right tab (settings) and then go to Advanced tab and then select Monitor
Here you should be able to change screens back to the LCD of the laptop
Dec 09, 2008 | Toshiba Satellite P30 P35 Series Notebook
I have to push the power bottom all the time. If i don't, it turns off and the light indicator goes off not amber or any other color. Now that i'm typing i'm pushing the bottom... Last night it was working...
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 26, 2008 | LG Flatron F700P 17" CRT Monitor
Hansol 730E 17" CRT Monitor Logo
154 people viewed this question
Top Hansol Computers & Internet Experts
donny ardalando
donny ardalando
k24674
ray gallant
Are you a Hansol Computer and Internet Expert? Answer questions, earn points and help others
