Question about Dell Microsoft Windows XP Home Edition
XP boot problem - only starts in safe mode. . need help
Can you help me troubleshoot this problem to completion.  System won't start in normal mode - and windows defender scan finds nothing. . .??  Please help.
  • Dell Master
  • 13,433 Answers
You will need to use the xp setup cd and perform a repair installation on the current windows.
Insert the cd, start from cd, press enter to install windows, ones it scans the harddrive and finds your windows select Repair, follow on screen instructions and complete the setup,.
Posted on Dec 13, 2008
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
My acer netbook (winxp) won't load after the mouse cursor appeared
Sounds like you need to run the check disk utiltity but since you don't have a CD Drive, you're up the creek without a paddle. try booting up into Safe Mode and if you get there successfully reboot and see if the normal mode works, if not you can uninstall Microsoft Security Essential in Safe mode. Or you can use System Restore to restore back to a point (date and time) when the system was working ok. Click Start/Programs/Accessories/System Tools/System Restore and select a restore point before you loaded Security Essentials. In Windows 7 just click Start then type System Restore in the search box above the start then look at the returned results and click System Restore.
System Restore does not lose any of your data, documents, music, pictures, videos or programs (unless the programs was installed after the date and time you selected).
To get into safe mode follow the steps below:
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
You can try to get to a dos command prompt or you can see if the system will allow you to boot in Safe Mode to get to the dos command prompt.
May 12, 2012 | Computers & Internet
Why the system automatically go to safe mode
If you are using Windows XP then you may have the /safeboot set in the boot.ini file which will force XP to always boot into Safe Mode.
When the system has started, click on Start then Run and type MSCONFIG as the command to run.
Open the Boot.ini page tab and make sure that the /SAFEBOOT option is not selected in the Boot options section of the page.
Save the change and restart Windows and it should start normally.
Dec 27, 2011 | Dell OptiPlex 780 Desktop Computer 1 x...
My computer works in safe mode, but it won't finish booting up in reg. mode. It locks up in the middle of starting and goes from a black bakground to a green one and it stops/freezes. It started doing...
Boot into safe mode, go to the start menu, all programs, Accessories, system tools, click system restore. Try restoring your computer to a date earllyer thin the installed sp3. Best wishes. Good luck.
Have a nice day!
Aug 23, 2011 | Gateway GM5048 (6304) PC Desktop
We have desktop xp and it is running on safemode how do we take this off
You can't take off Safe Mode, it's there for your protection. However, if you want to boot into Normal Mode, shut down the computer. When you hear the computer beep, start tapping F8 on your keyboard. Keep tapping it until you reach the Advanced Options menu. Once you've reached this, just select "Start Windows Normally".
Now it will boot you into Windows on Normal Mode, not Safe Mode.
Jan 01, 2011 | Computers & Internet
Windows XP how do you get it out of safe mode
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 16, 2010 | RCA VR702HF VCR
Aspire one notebook will not completely boot. It
While the system is booting --before the xp logo shows, hold down the F8 key. This will bring up a menu. Choose "start windows in safe mode with networking".
The os will start in safe mode. run a virus scan, defrag and scandisk, then restart the system. If is still wont boot normally, do the same thing then run a registry fixing program such as uniblue registrybooster, then reboot. If it still won't boot you may have to reinstall the OS. good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Apr 23, 2010 | Acer Aspire One PC Notebook
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Power failure, Windows XP was on, boots ok but now ultra slow.
Try running the performance & maintenance option under the control panel. First run a disk cleanup. When that has finished run the system defragmenter. When this is completed reboot and see if your problem is corrected. Hope this helps.
Mar 13, 2009 | Computers & Internet
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
35 people viewed this question
Alun Cox
