Question about Logitech QuickCam Pro 4000 Webcam
I cant use any video effects
Im having a problem with video effects on my logitech communication duluxe i keep getting error code 0x80040606 and that happens on any effect i try i cant gett it to work and i have look on all the replys i could find to help me did all they said i had to and i still get the same problem my webcam works perfectly in both photo and video and can switch to all sizes available actualy the only problem is the fun effects everthing else works perfectly if any1 can help me resolve this thank you if you want more details ask
  • 1 more comment
  • Anonymous Jan 22, 2009
    i have the exact same problem but on a different logitech webcam
  • kablchic Mar 09, 2009
    I have the same problem with the Quickcam deluxe. It was working fine and then one day it just didn't have any of the effects. I get the 0x80040606 error. I repair it once and it worked for a day, but it's back to throwing the error again. I've loaded the disc again with the firewall up and down, but still get the error. Is there a fix?
  • chris johnson May 01, 2009
    ty for the post but i still get the problem im am gratefull for the post ty just need more help
  • 3 Answers
1152x882 Normal 0 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Ref: Face Accessories, Error Code 0x80040606:
I may have stumbled on a solution. In the past every time I installed the software from the CD it turned off the Windows Firewall.
The Webcam worked for a few hours then began showing the error.
This time, I turned off the Windows Firewall, the anti-virus software, and Windows automatic update. After installation, I turned all of them back on.
The Webcam has been working flawlessly for the past two days.
I think there is more then one culprit that causes the error.
First, the Windows Firewall second is when one adjusts the Taskbar using msconfig.
I strongly suggest that you do not turn off any of the installed Logitech startup icons.
Posted on Jan 24, 2009
Error 0x80040606
It is a registry error code.
Nov 20, 2009 | Logitech QuickCam Pro 5000 Webcam
Tip
Thanks Nitrotrike for your suggestion. The Logitech Effects work after the...
If you are using Windows XP, and have tried to use the avatars or effects on a Logitech 4000 (and most other Logitech cameras) and the green arrow is 'grayed out', this is what is wrong:
Some of those 'speed up your computer' programs tend to disable un-needed services which run in the background of Windows.
Unfortunately, Logitech software needs one of these services to run in order for the avatars and effects to work correctly. Even Logitech themselves don't know why it needs this service running, but it does!
Keep in mind, this is a tip for Windows XP!
To make sure the needed service is running:
1. Click 'START', and go into 'CONTROL PANEL'
2. Once in control panel, click on 'Administrative Tools':
3. In Administrative tools, click on 'Services':
4. Scroll down to the 'Terminal Services'. (the screenshot shows Indexing Service):
5. If you see that 'Terminal Services' is disabled, that's your problem!
6. Highlight 'Terminal Services' and right click on it. Choose 'Properties'.
7. Change the 'Startup Type' to 'Automatic'.
8. Click 'Apply', then 'OK'.
9. Close out of the services menus.
Restart computer, and enjoy your avatars!
on Apr 02, 2008 | Logitech QuickCam Pro 4000 Webcam
ERROR on Quick Cam
try reinstalling the video effects software
Jun 13, 2009 | Logitech QuickCam Pro 5000 Webcam
I have a logitech webcam s 5500 and I try to use the video effects but get error message "Capture failed with error number %d, error code = 0x80040606". How do I fix. Thanks
Normal 0 Double Click on this site
http://www.free-codecs.com/download/AMCap.htm
to download the Free AMCAP Video Capture Program.
AMCap v9.20 AMCap is a small yet fully functional video capture application compatible with Microsoft DirectShow. It is based on the sample AMCap from the Microsoft DirectX 9 SDK. AMCap supports still captures to BMP, JPEG and PNG formats and it remembers your Video Input, Video Standard and Video size settings from previous session. It has some nice features like multimonitoring support, zooming, aspect ratio and deinterlacing features.
AMCap is a small and effictive piece of software and definitely worth trying. Hope this will help. Bud
Mar 23, 2009 | Logitech Quickcam Web Webcam
Can someone help me fix this
Using a Webcam like Logitech QuickCam® Messenger onWindows Vista, Internet Explorer 7 sometimes an error such as0x80004005 / 0x80040606 appears.
Try this workaround and disable UAC.
Goto Start Menu > Start Search > type: "msconfig" >
Tools Menu > Disable UAC > Launch > Apply > OK > Restart.
In general though - you should not have to disable this security featureof Vista in order to install and operate the Logitech software.
If this workaround works, then it is a flaw in the program and you should contact Logitech customer support directly.
Sorry for not having "the" solution on hand, but I've seen many people having that problem. Some changed to a prgram called "splitcam" becuase they were tired of Logitech's sloppy software.
Jan 16, 2009 | Logitech Quickcam Chat Webcam
Cant record video-- keep getting error code
Never mind--- Just needed to restart the computer-- works fine now!
Sep 29, 2008 | Logitech Quickcam Chat Webcam
Webcam
I had just received a Logitech Orbit AF Webcam for graduating a 4-year University with nearly perfect grades & a 3.98 G.P.A. I had tried to use an avatar instead of my picture and a popup window said
"Error Code = 0x80040606."
WHAT IS THE PROBLEM???? This is NOT a cheap camera! Why am I having these problems and HOW DO I FIX THIS??????
Luthier207@hotmail.com
Sep 06, 2008 | Logitech QuickCam Pro 5000 Webcam
Trying to get a xbox360 cam to work in aim video chat
Will not work you need an Xboxlive cam. they run about $30. The system doesn't have the drivers to run the other camera.
Jun 18, 2008 | Logitech QuickCam Communicate STX Personal...
Logitech Quickcam Pro 5000 Video Effect Error Code= 0x080040606
If you're like me, and you have "thinned" out your Windows, or used any of those programs to "speed up" your computer, make sure "terminal" is enabled in your services. For some reason, this wont allow video effects to work. Very common problem. Good luck!
Dec 11, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Pro 4000 Webcam Logo
393 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
