Question about Sony KP-51HW40 51" Rear Projection Television
Sony Projection Tv Model KP-51HW40
Won't start , blinking red led in front. Push power button, led blinks different pattern, I hear the set try to turn on thru clicks and then clicks again and led goes back to a standard pattern of blinking. Color is always red. Any help would be greatly appreciated. Thanx
  • 2 more comments
  • Wayne McEathron
    Wayne McEathron Dec 13, 2008
    First plug in- no red lite- pushing power button blinks 4 times slow then blinks 6 at a faster pace and stays there. Stops 1 sec. blinks 6 over and over...push power button again blinks 4 slow pace then 6 at faster pace and stays continually blinking the 6.
    Thankyou for such a quick response...hope you can help.
    Sincerely,
    Wayne
  • Wayne McEathron
    Thankyou...definitely helpful !!!!
    Think this could get costly to repair ? Just Curious.
  • Wayne McEathron
    Understood...again Thankyou for your help !!!
    Happy Holidays to you and yours !!!
    Sincerely,
    Wayne McEathron
  • tvguy171
    tvguy171 May 11, 2010
    How many times does the light blink? This is an error code to help diagnose the problem
  • 106 Answers
With both of error codes flashing, the problem is trying to figure out wich one to focus on. The flashing 6 code is an indication of HV failure which would then cause a vertical failure(4 blink code). There are so many things that would cause this problem. I can narrow it down to the "D" board to fix your problem. If I were there to troubleshoot it, I could narrow it down further I.E. flyback, HV distribution block. I suggest getting a tech diagnose the exact problem. I wish I could narrow it down better for you. Please take time to rate this solution and if I can be of further assistance, let me know
Posted on Dec 13, 2008
  • tvguy171
    tvguy171 Dec 13, 2008
    Depending on the what is causing the problem and of course the area you live in. If the "D" board has to be replaced it could cost in the neighborhood of $400. When I get a call to fix these sets, I try to diagnose it down to a certain component or circuit thus keeping it as inexpensive as possible.
My kp-57/65wv600 flashes SIX TIMES, PAUSED ABOUT 3 SECONDS AND BLINKS SIX TIMES OVER AND OVER! WE PUSH THE POWER BUTTON AND WE CAN HEAR WHEN TURN ON AND OFF, BUT NO IMAGE/PICTURE APPEAR. THANKS!
First off I would check your lamp to make sure it isn't burnt out. Usually the lamp door is on the backside of the TV. On my 2006 SXRD its on the right side of the TV just behind the buttons. Here is a link to a diagnosis page
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Jun 30, 2011 | Sony KP-51HW40 51" Rear Projection...
I have no picture and the power light flashes green and then red.
I can help you to solve your Sony tv problem.
Is it Sony KP-51HW40 tv or any other model?
How many times red light start blinking after three seconds long pause?
Let me know to proceed, can you check voltages with multimeter in tv circuit board?
Thanks.
Nov 26, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-57ws520 tv dont come on
There is no lamp fuse in this type of TV. I will check on the error codes for this set and get back to you.
michtech
Feb 18, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53HS10 rear proj TV - picture goes on & off
If the adjustment of the screen settings does not fix your problem, its likely that one or more of the CRTs (picture tubes) is defective.
And, the CRTs for these sets are hard to find and expensive.
michtech
Jan 29, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 6 blinks
Hi Yeooow,
I guess you read the fix for my set wth the six-blink error. If not, here's the link:
http://www.fixya.com/support/t647530-tv_couldnt_turn_no_picture
My set is a KP-53HS30, chassis number P65A-A.
I found a bulged capacitor on the "G" power supply board and replaced the components associated with that circuit (6-volt regulator). If your set has the P65A chassis, I'd be happy to e-mail you the service manual I have, if it will help.
-Dan
Sep 04, 2008 | Sony KP-51HW40 51" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51hw40 -No power
check all the fuses especially the pico fuses on the D board as the led should at least light up if the fusese are all good, then the set should throw an error code when you try powering it up. Let me know if you need more assistance
May 18, 2008 | Sony KP-51HW40 51" Rear Projection...
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Sony projection tv
Fisrt off think of the age of the set. and then ask yourself do you really want to start sinking money into such an old unit? My advice, free as it may be, save your money for a new set. These older sets can be regretably costly to repair. Be warned.
C-Dog
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
156 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
