Question about Sony Playstation 3 (PS3) Console
My ps3 tells me the hard disk is corrupted
When i turn on my ps3 it says "the hard disks file system is corrupted and will be restored press the ps button to begin. X enter" i press the ps button and then X it then tells me" restoring do not turn off the system" when it gets to 100% it re-boots itself and i still have the same problem
I had the same problem and had to send it back to sony for replacement. if no longer under warrantee they have a $149 flat fee to fix or replace unit. call them and they send you a postage paid ups box and drop it off at a ups store.
Posted on Dec 16, 2008
    Problem Solver:
  • 3 Answers
Sounds like you might need a new hard drive. You could try to disconnect it and reconnecting it, but usually it does not fix the problem. just remember you need a 2.5 sata hard drive (might be a good thing, if you ever wanted more hard drive space).
Ps3 says hard disk's file is corrupted and will be restored starts restoring then goes back to screen saying hard disk's file is corrupted.what can i do now?
follow this procedures its a solution to corrupted hard disk.
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good luck.
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
My PS3 says on screen: The hard disks file system is corrupted and will restored. ok Press the PS button to use controller. But when I press x nothing happens
lsn if ur PS3 under warranty then send it to them and they will give u a brand new one, but if not just change the Hard Disk and u can choose any Hard Disk size u want
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
Hard disk file system corrupt
Bad sector or MBR on Hard drive needs replacing
Mar 21, 2010 | Sony Playstation 3 (PS3) Console
When switched on a message comes up.THE HARD DISKS FILE SYSTEM IS CORRUPTED AND WILL BE RESTORED. PRESS THE PS BUTTON TO USE THE CONTROLLER. X ENTER. restoring do not turn off. once this is complete the...
Easy fix. Hold down the power button on the system until it turns red. Release, and repeat. Release and repeat, only this time wait until you hear 2 quick beeps. Release quickly and then you go into Safe Mode, Choose option 5, PS3 System Restore. This will also reformat your disk. System will automatically restart when you complete the system setup. Only warning is you lose all login info and possibly content you have downloaded. You are done.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
The hard disk file system is corrupted how do i
johnnolan1
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted.
Most likely your hard drive is completely corrupted. It could be as simple as a new Hard Drive replacement or as complicated as a motherboard issue.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 09, 2009 | Sony Playstation 3 (PS3) Console
Hard disk corrupted
just keep trying restoring hard drive adventualy it will work
Jan 16, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
