Question about Microsoft Xbox 360 Console
Cutting off 2 mins into the game
I just got my xbox back from Gernmany where it was being fixed (red ring). I literally just turned it on to play some fifa 09 - it worked for about 30 seconds (let me pick language) then cut out and gave me a black screen.
When i turn it on it makes a jumpy grinding noise. Other games are working - i know fifa works as i only had it two days before i got red ring of doom and i played it last night at my friends.
If u have any ideas - please respond.
    Problem Solver:
  • 3 Answers
That happens to me once in a while too. What you do, try taking the disk drive out and run it under hot water for about 20 seconds. Then, dry it thoroughly. Put it back in and it should work.
Posted on Dec 13, 2008
2 rings of death only when a play a video game. I had 3 red rings, then I did an x-clamp fix , cleaned GPU and CPU and applied arctic sliver to the xbox. When I start up my xbox it show no red...
Hello there
From what you have said it sounds like you have the RROD - 2 RED RINGS ERROR
The main causes are Hardware failure, overheating or wear & tear.
You may need to perform simple maintenance, clean or in some cases adjust settings.
To get the best advice on where to start I recommend a GOOD REPAIR GUIDE, From this you can fix the problem at home and avoid any large repair bills. Its easier than it sounds when you have help from the guide.
I used Gamer Fix to get the best guides
The other solution would be to send the console off to its manufacturer, This is free if your still in warranty. If your console is out of warranty then the usual price of repair is $150
I am Glad I could help and You can help others by rating this Post or leaving a comment.
Many thanks
Peter Fix
Jan 05, 2011 | Microsoft Xbox 360 Console
After playing a game for 5 min. or less playing on an xbox 360, the screen turns off and the xbox has 2 red lights on the ring of light the console is still on and the controller is still doing what it was...
2 red lights is overheating, try giving it a dust out and if this does not work you will need to stop the heat build up inside.
To do this you can send it in or use a good Xbox 360 Repair guide to fix it.
Jan 20, 2010 | Microsoft Xbox 360 Console
2 red rings playing for 40 min
2 Red rings is caused by the Xbox 360 overheating. This should not be happening after 40 minutes of play.
You can check your warranty status here.
If you'd like to repair it yourself check out:
www.xbox-experts.com
Nov 20, 2009 | Microsoft Xbox 360 Console
My game plays for a min then frezers and gives me the 3 red rings
the red rings can be fixed in 2 different ways.
1) take all cords out except power corad and wrap it in thick DRY towl. then turn it on and let it overheat, this works 85-95% of the time.
2) send it in the console(you need the reciept)
and get it fixed/replaced.
NOTE:you can try both, if 1 doesnt work you can always do 2
Jul 12, 2009 | Microsoft Xbox 360 Console
your xbox 360 is overheating its called the red ring of death look it up on google you can have microsoft fix it if you still have a warranty on it, it shuts down so none of the components in the xbox 360 get damaged
May 30, 2009 | Microsoft Xbox 360 Console
Flashing red lights
Your xbox might be overheating. Read http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907533&lcid=1033&category=hardware for more information.
Apr 10, 2009 | Microsoft Xbox 360 Console
During game play,game shuts off and two red rings appear/
its very possible your xbox is having overheating problems. I had the same issue with mine, and i had to send it back to microsoft 2 different times, but after that it worked fine. I would try sending it back to microsoft, and see what happens from there.
Mar 30, 2009 | Microsoft Xbox 360 Console
Dont do those fake youtube videos this is how I fixed mine after trying endless Internet hoaxes http://xbox360repaircenter.info guarantees you be playing in 2 hours for cheap
Nov 29, 2008 | Microsoft Xbox 360 Elite Console
asdasdhgaiouhsdpgiohasd;ilgkhas;doilgk
Oct 28, 2008 | Microsoft Xbox 360 Elite Console
Two red rings
The 2 flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 2 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 2 red lights. Even before you get the 2 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 2 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that's all.
There is one more option available in the form of DIY Video Guide, that will explain you step by step approach to fix red ring of death within one hour without any technical knowledge.
Jul 18, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
