Purchased on 4/4/10. I would really like to avoid high cost repairs. Is there anything else that could be wrong?
SOURCE: frigidaire gallery dishwasher fdb949gfb2
it looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
SOURCE: Flashing "Washing" light on my frigidaire 1000 series dishwasher
Possible solution. I had the same problem of "washing" light flashing last year and now today. Warranty has been expired for awhile, so no harm in trying. What worked for my situation was removing the six screws for the back of the plastic control cover. Take of the plastic cover. There are are two connectors to the HANDLE with white and black wires. To be safe I would shut off the ciruit to the dishwasher. Safety first. Carefully disconnect and inspect the contacts inside the connectors. Do not insert any metal objects if you left the power on. I believe that the moisture from the dishwasher can degrade the connectivity. I cleaned the contacts with q-tips and re-installed. Be careful to not bend the contacts. If you had sound, you could hear my dishwasher running. Total cost is about three cents. I believe that the connectors do not full close when corroded, which prevents the completion of the circuit to the controlls. The flashing light indicates that the door is open, when in fact it is closed. Hopefully this will help someone. Semper Fi
SOURCE: My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Hello jajarmer - From what you are describing the dishwasher could possibly be experiencing a communication problem with the main control panel, faulty keypad or potential wiring failure. Try to reprogram the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. If issue persists, and if I was in your position, I personally will recommend consulting a professional to determine the root cause to reduce the risk of unnecessary parts.
Hello Stephanie Shcherban - Try resetting the unit by unplugging it for flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and first confirm that the "child lock" option is not selected. However, if it proves to be ineffective and from what you have a described it sounds like the unit has a defective door lock switch, which will need replacing. Contact a professional to move forward accurately.
