Question about Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers
Subwoofer hums under power not hooked to system & hooked up?
Subwoofer hums
    Brigadier General:
  • 6,966 Answers
This may or may not apply to your particular problem. On similar humming sound problems, I normally would look for either a fault in the input side and/or a leaky/defective capacitor in the power supply. On the input side, this may be a frayed shielded wire, loose connector (esp. the outer which is normally the ground). Try completely removing the connecting/input cable that goes into the subwoofer. If that doesn't work, then it you may want to check the big capacitor in the power supply section of the subwoofer. If you are not that familiar in working with power supplies, may I suggest that you ask any electronic technician to have a look at it since capacitors store a rather hefty voltage. Better be on the safe side. Hope this works out ok with you
Posted on Apr 08, 2007
SOURCE:
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Why does my HTS-20 powered subwoofer make a low hum when plugged in, even turned off and not connected to the receiver and a louder hum when the subwoofer power is turned on?
I suspect the amplifier is damaged. This is not an easy repair to do unless you are well versed in audio electronics. I would recommend a repair shop to look at the subwoofer amplifier.
Jun 03, 2015 | Infinity HTS-20 System
Velodyne dps 10 rca hums but wired is fine
The issue a floating ground that causes the hum you are talking about. What are you connecting it to that causes the hum?
Jan 07, 2014 | Velodyne DPS-10 Subwoofer
After a power outage I have a loud hum.
Hi, The Ground Rules Of all the annoyances that can afflict any audio/video home theater or even a simple stereo installation, the notorious "ground loop" may well be the most difficult and persistent one to track down and eliminate. A "ground loop" is caused by the difference in electrical potential at different grounding points in an audio/video system. (All the grounds in an A/V system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio or video components, including subwoofers, cable-TV outboard boxes, satellite-TV feeds, TV displays, amplifiers, A/V receivers or turntables. The buzz/hum is a byproduct of the multiple power supply cables and a ground voltage differential within your system and its network of interconnecting cables.
Here are some methods to help you get rid of ground loops. Try these first and don't waste money on a power "conditioner" which, in most cases, won't help. (There is no need to "condition" the AC power for your system. Your receiver or amplifier already has a power supply with its own filters and transformers. No further filtering is normally required.)
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your cable-TV or satellite-box feed at the entry point to your system.
First, the subwoofer: unplug the coaxial cable that connects to your powered subwoofer to see if the ground-loop hum disappears. If it does, it's likely coming in through your cable/satellite TV feed.
Reconnect your subwoofer's coaxial cable from the subwoofer input to your receiver's subwoofer output and disconnect the cable-TV feed (or satellite feed) from your outboard set-top cable box or satellite tuner. Be sure and disconnect the cable before any splitters. Now see if the hum/buzz from your subwoofer stops.
If that eliminates the hum, you can install one of these inexpensive in-line ground isolators from Parts Express or Bass Home. Note that these transformer-based ground isolators will work fine with analog cable-TV feeds, but depending on their design they may interfere with or block reception of HDTV signals via a digital cable or satellite dish feed.
Install the ground isolator between the cable-TV feed and the input of your outboard cable-TV box or satellite tuner (or the TV display's antenna or cable input if you have a set with a built-in TV tuner or a cable-card ready set). In many cases, the ground isolator will "break" the loop and remove the annoying hum or buzz by isolating the TV-cable ground.
If a hum remains with the TV cable completely disconnected from your system, or you don't want to risk degrading reception of HD signals from a cable or satellite system, then you may have to add a ground isolator like this Radio Shack Model 270-054 between the line-level coaxial subwoofer cable from your A/V receiver and the line-level input jack on your powered subwoofer.
In all cases, if your subwoofer has a ground-lift screw like some of Axiom's subwoofers, try first removing the screw (or replacing it) to see if it increases or eliminates the hum. It may or may not make a difference.
If you do not have easy access to the aforementioned ground isolators, here are a few more tips:
Try plugging the subwoofer into a different AC outlet in the room, one that isn't supplying power to your components (A/V receiver, TV, cable box, etc.). That might fix it.
Try reversing the AC plug for your A/V receiver or the powered subwoofer. If it's a 3-wire plug or a polarized plug, which has one prong wider than the other, you won't be able to reverse the plug. For safety, do not use a "cheater plug" to bypass the 3-wire plug.
With the power OFF, reverse the AC plugs one by one of any other components that have a standard 2-prong AC plug that isn't polarized. Each time you reverse a plug, turn on the system with the attached component and your subwoofer and see if the hum disappears. In some cases, reversing one or more plugs will eliminate the hum.
If you have a turntable, try connecting a separate ground wire to a chassis screw on your preamp or receiver and see if the hum disappears. If you already have a turntable ground wire, try removing it from the preamp. One or the other may eliminate the hum.
Finally, here is another solution that worked well for a member of our message boards who decided to discard his ground-loop isolator on his subwoofer: "I took off the ground-loop isolator I'd been using and connected a plain 14-gauge wire to chassis screws on the sub and the receiver then powered everything on. Although hum was still there, it was far lower than before. Next I unscrewed the ground-loop screw on the back of the sub and that took care of the hum completely."
Almost certainly sounds like an earth loop to me, but can be caused by a poorly made transformer or phase shifts on the mains supply. Visit some power conditioner web-sites like Isotek or Isol-8 (or google "earth loop") where there's plenty of advice on how to reduce/eliminate earth loops and other causes of mains-induced hum (transformer problems etc).
Hum on the speakers usually indicates that there is a DC voltage on the speaker line. DC voltage on the output lines would be caused by a shorted output transistor.
Have a nice day...
Feb 16, 2011 | Cambridge Soundworks BassCube 12 Speaker
I recently moved and am having trouble getting my phillips subwoofer system model : MMS171W hooked up properly There is a loud background hum when I attach it like I think it should be attached. Any ideas...
This is most likely a "ground loop" and is caused by using two different electrical outlets for the two parts of the system -- main receiver and subwoofer amp.
Try using the same electrical circuit (wall outlet) for all of the equipment in the home theater, using a power strip or strips as needed.
Nov 07, 2010 | Philips Audio Players & Recorders
Humming noise when amp is powered on.
check the heatsink, touch it with your finger feel it ,if you can hold it with in 15 sec, then your power amp. component might be working if not then probably you Power Amplifier IC or transistor is shorted.
May 31, 2009 | Infinity BASSLINK Car Subwoofer
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Hum in subwoofer
If you have cables hooked up and have not installed them to the components when turned on the speaker will hum.
If your electrical outlet is not grounded properly you speaker will hum.
Personally I'd take it back and get a new one. if you just purchased it.
If this happens again try a grounded curcit first then go from there.
Oct 22, 2007 | Jensen JHT525 System
Loud humming coming from subwoofer
This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
Sep 04, 2007 | Audio Players & Recorders
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
645 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
