Question about ASUS A8N32-SLI Deluxe Motherboard
After 15mins it locks up
I tried to run a mem test but cant get through the test
  • ertg Dec 13, 2008
    my son ran memtest+
    after 15 minutes it froze, which leads me to believe its either the RAM or the Mobo.
    any other idea's that may help narrow it down?
  • 827 Answers
You can download an .iso file called memtest+ that you burn onto a disk and run when you reboot your computer. you'll have to make sure you have cd-rom as the first boot device in your bios though.
you can also download the same program to boot from your USB key, if you have one, and just make that the priority boot device in bios for that method.
here's the download link, download whichever one suits you best..
http://www.memtest.org/#downiso
good luck
chris
Posted on Dec 13, 2008
  • chris grams
    chris grams Dec 13, 2008
    i had a memory problem before where i took out the ram in the first slot and put the ram from the second slot into the first slot. i just ran a test with only one stick of ram in and it finished fine. all i could tell from that was that there was a problem with the first stick of ram. i'm not sure how comfortable you would feel about opening the machine up, but it worked for me. i never did resolve what the problem was with the dodgy stick of ram, but at least it isolated the problem and it stopped my computer from crashing.
    that's all the ideas i got mate.
    if you do decide to bite the bullet and buy a new stick of ram, make sure the stick with the largest amount of memory is in the first slot before you boot up.i don't know exactly why, but i've read that this is extremely important.
Toyota heater no warm air for 15mins
Sounds like an air lock!
To Check....
With engine cold set heater to hot position.
ID return pipe from heater under the hood. Remove the return pipe at one end to check if coolant is there ( it should run from heater pipe) if no coolant you have an air lock.
To remove air lock top up coolant header when engine is cold. Leave heater in cold position replace pipe and start engine. Allow it to come to working temp then set heater to hottest position. Allow a few seconds and check if the pipe you first removed is hot. If no then ease the securing clip and carefully allow air to escape while engine is running... place a cloth over this area to prevent hot coolant spraying out. When coolant appears re-tighten pipe.
"PLEASE BE VERY CAREFUL DOING THIS AS COOLANT WILL BE EXTREMELY HOT".
If you're not confident enough to do this ask a qualified mechanic to do it for you.
Again please be careful.
Oct 24, 2013 | 2000 Toyota Land Cruiser
How do i find and swap computer chips
ECM LOCATED IN THE PASSENGER COMPARTMENT BY THE RIGHT SIDE KICK PANEL OR BEHIND GLOVE BOX.WHEN YOU FIND ECM.LOOK AT PART NUMBER ON ECM MAKE SURE PART NUMBER RIGHT.NOW ECM HAS A MEM - CAL ACCESS COVER.REMOVE ACCESS COVER.TO REMOVE COMPUTER CHIP OR MEM - CAL.FIRST YOU USE TWO FINGERS PUSH BOTH RETAINING CLIPS BACK AWAY FROM THE MEM - CAL AT THE SAME TIME GRASP THE MEM - CAL AT BOTH ENDS THEN LIFT IT UP OUT OF SOCKET. WHEN INSTALLING NEW COMPUTER CHIP OR MEM - CAL MAKE SURE YOU HAVE RIGHT PARTS NUMBER IF NOT YOU WILL DESTROY NEW CHIP.WHEN INSTALLING NEW COMPUTER CHIP OR MEM - CAL PRESS ONLY ON THE ENDS NOT THE MIDDLE.WHEN DONE.DO A DIAGNOSTIC TEST.TURN THE IGNITION SWITCH ON.ENTER DIAGNOSTIC MODE AT THE ALCL.SEE CODE 12 ALL IS GOOD IF YOU SEE CODES 41 42 51 OR 52 YOUR MEM - CAL OR COMPUTER CHIP NOT COMPLETELY SEATED OR DEFECTIVE.TO BE ON THE SAFE SIDE TAKE WHOLE ECM CASE TO DEALERSHIP LET THEM GET YOUR PART NUMBER OFF OLD ECM UNIT.THAT WAY YOU CANT GO WRONG.
Sep 14, 2010 | 1988 Chevrolet K1500
Keyboard mouse pad no working
ok my friend this happend to me. if a desktop get an add in pci card. notebook, go and get a usb pcmcia card if you have a slot on the problem unit. (or express card) whatever yours has. use external keyboard+mouse and you can at least use it again. good luck .
Feb 19, 2009 | Acer Aspire 5100 Notebook
Surround speakers work in test mode but won't come on during play
Check that you set it to Pro logic and check the speaker set-up. Set it to 5.1 Sounds like somthing is in the wrong setting.
Dec 22, 2008 | Yamaha HTR-5830 Receiver
My dell wouldnt post,
It sounds like the motherboard is damaged. Did you try to start with a boot cd? Or will it just not get to the bios setup screen?
Nov 28, 2008 | Dell Dimension 3000® Pentium® 4...
Cant set the clock on my Wharfedale ip76 stereo.
Hold down iPod/MEM/C-ADJ till it flash's 24 Hours, choose between 24 & 12 hour clock, press MEM again to move onto hours, MEM again for minutes, MEM again to save the time
Nov 15, 2008 | Wharfedale Open Box WH-LOUDM-LIM LOUDMAN...
Mobo reads less ram than windows
possible that you have incompatible mem installed, the archictecture of the mem could be 32mb x 64bit could mean that the "BIOS" may only be able to see 32Mb x 8 which to me suggests that this is not the correct mem for this Motherboard, is this mem recovered from another system or an old board. Try Kingston.com and use their memory configurator to find the correct mem for your motherboard (enter the MB manuf and model)
Aug 16, 2007 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
Does not read memory card
Casio only tested 3 cards with the camera. Sandisc, Toshiba, Panasonic. First: Format the internal memory of camera and then reset camera. In rec mode press menu go to setup tab go up to format press right arrow highlight format press set. Follow same steps for resetting. Then insert mem card and format mem card. If that still doesn't work I would say there is something wrong with the camera itself and would need to be sent in.
Jan 24, 2007 | Casio Exilim EX-Z57 Digital Camera
ASUS A8N32-SLI Deluxe Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
