Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Ceiling fan light flashes
I have a 54" Hampton Bay Windward II Celing fan that the light would not turn off. I reset the electrical at the circuit breaker, it now works but flashes on and off.
  • 4 more comments
  • got2havit
    got2havit Dec 13, 2008
    I have the same exact issue with mine. I just this moment finished dismounting and reinstalling. All of my electrical was and is correct. I also reset my remote and control box to an alternate code just to be safe. I will keep you posted if this worked. Regards
  • jmaccheyne Dec 27, 2008
    Did either of you find a solution? Exact same problem with mine.
  • Allen Neal
    Allen Neal May 11, 2010
    HOW LONG HAS THIS LIGHT BEEN INSTALLED AND DID IT WORK PROPERLY AT ONE TIME ALSO WHAT TYPE OF SWITCH IS INSTALLED TO OPERATE IT
  • adamnakata
    adamnakata Jan 22, 2012
    The solution below worked for me, thanks for posting, saved me a huge headache!
  • Shawn H
    Shawn H Jan 07, 2014
    I have a Hunter ceiling fan. The owners guide says Type 2 models, I don't know the exact model. The owner's guide also says the might kit is limited to 190 watts. The lights have worked with no problem with four 40 watt bulbs since we installed the fan 4 or 5 years ago. Recently the lights began to flash approximately 1 to 2 seconds to cycle on and off. They flashed continuously whenever they were turned on. I removed a component labeled model: 98480X part: 98480-02 and desired to bypass the removed component and the lights work perfectly, no flashing.
  • Scott Schoemann
    Scott Schoemann Apr 20, 2016
    Quite often flashing lights are the result of damaged sockets that the bulbs screw into. this can result from the bulbs no being ******* in tightly in, or from using too high of a wattage bulb in the sockets, the light kit is rated for a total wattage, not individual bulbs at that wattage
There is a small part in the light kit of the fan connected to the lighting circuit. The part is relatively common to these fans and is most likely in yours as well. The sticker on the side of it shows model 98480X part number 98480-02. Clip the leads to remove this part and wire-nut the wires back together bypassing it (black/red to black and white to white). This will get your unit back to normal and the switches will still work. I spoke with Hunter and this part has nothing to do with the remote control features of the fan. It is a wattage limiter. If you attempt to put bulbs into the fan that are higher than the recommended wattage this unit steps the voltage down to prevent overheating and possible electrical issues. Removing it will not prevent the fan from functioning but you should be aware that it is in there by federal regulation requirement and without it you could risk electrical failure or fire if you put bulbs in that are too high a wattage. If you call the manufacturer to report the issue they will send you a new lighting housing for your unit which will have a new limiter in it and solve your issue as well. In my case I needed the light working so I bypassed it then requested the part. In the meantime I just made sure that the bulbs I was using were well within spec. In my case the limiter was just on the light, but depending on the model or how the wires were nutted together by your electrician if the fan was also nutted on after this device it would certainly have issues as your bulbs would now be limited to the total wattage of the bulbs and fan combined. Hope this helps all!
Posted on Nov 23, 2010
  • 4 more comments
  • jllynch79 Aug 11, 2011
    thank you, I followed you directions and it was right on.
    this worked great. no trouble to fix thanx for your expert advice
    th
  • Dan Newlon Sep 08, 2012
    You are on the ball, and you have helped my make my wifes day!!! For two years we thought there was something wrong with the wiring and couldn't ge the electrician to come back and fix it. I removed this part and the problem is gone! Thanks again.
  • Paul Alexander
    Paul Alexander Mar 01, 2013
    There is a work-around trick that keeps the lights from flashing. If you are using CFL's it causes the flashing. If one CFL is replaced with an incandescent light, the flashing stops.
  • Jeffrey Frie
    Jeffrey Frie Sep 01, 2013
    Thanks a million...I procrastinated for months, but fixed it in 15 minutes with this advice!
  • jumon Jul 03, 2014
    Clipped the leads and then used the wire nuts inside the unit to bypass the POS wattage limiter. I never plan to use bulbs other than CFL or LED, so never going to be a wattage issue.
  • John
    John Sep 03, 2014
    John, Same here, fixed in about 2 minutes
    New Friend:
    Problem Solver:
  • 3 Answers
Regarding Hunter Light pulsing, the part 98480-02 on mine has multiple wires coming out of it. So it is for the fan and the light. The solution was simple. I took the red wire labeled (Light In) that is coupled to a black wire then connected to another black wire with a wire nut. I removed this wire nut, then put a small piece of electrical tape and the wire nut and capped it off. "A" & "B" were connected with the blue wire nut. Took it apart and capped "A" and connected "B" with "C" using a larger wire nut. Very Easy! with tCeiling fan light flashes - 3_2_2012_4_14_49_am.jpg
Posted on Mar 02, 2012
  • 21 Answers
I found a site where you can get the manual for your hampton bay ceiling fan free here
Hampton Bay Ceiling Fan Manuals
If you cant find your particular model then leave a comment and they will find it for you
Posted on Sep 30, 2015
3 Suggested Answers
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
  • 75 Answers
SOURCE: lost screws to attach fan blades on ceiling fan
This is not a 'promo' for Home Depot but you will find the screws there that you need.
You will need 15 screws, with an 'unfinished' appearance, for the attachment of the five blades to the arms, and 10 screws that have a smooth rounded finish to attach the arms to the motor housing. If they do not have it in stock they can order ot for you.
If you have an electrical fan store in your area you should be able to find the items there as well.
If you have an old discarded ceiling fan, take the screws out of it and try them on your current fan, they should work.
Good luck. :)
Posted on Apr 26, 2009
Instalation diagran for windward II speed control unit
I thought this fan comes with a remote. You can't use both.
Aug 03, 2014 | Hampton Bay 54 in. Windward II Brushed...
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
We have a hampton bay ceiling fan model 54cvt. We cant figure out how to change the light bulb or change the direction of the blades. We dont have a manual for the fan.
This fan is also known as the Hampton Bay Covington 54 Ceiling Fan. You need to turn the globe anti clockwise until it comes out. The full instruction manual can be found here.
http://lightingworldbay.com/hampton-bay-covington-ceiling-fan-54-cvt-manual/
If you have another fan model other than the Hampton Bay 54CVT then try here
http://lightingworldbay.com/hampton-bay-ceiling-fan-manuals/
Jun 28, 2009 | Hampton Bay 52 In.Carriage House II in...
Broken glass cover for Hampton Bay Cruiser ceiling fan.
go to Home Depot, not only do they have replacements, but they can order for you what you need.  Hampton Bay is the Home Depot brand.
Mar 31, 2009 | Hampton Bay 04345 Cruiser Ceiling Fan
Lost screws to attach fan blades on ceiling fan
Good luck. :)
Mar 15, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 | Dryers
Problem with Hampton Bay 54 In. Flemish Pewter Ceiling Fan With Heater
did you check the circuit breaker to see if its tripped?im assuming the voltage rating of the wires your decribing are 110 volts and the fan likewise.the white wire could possibly be a neutral wire,meaning you should hook up the red and black wire.let me know
Jul 30, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
8,492 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
