Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman Evcon Heater drain tube backup
For the past couple of days, every time my heater
turns on, water comes up from the floor by the drain tube. Is this clogged, frozen, etc? There appears to be sand deep down in this tube - could this be going directly into the ground?
    Sergeant:
  • 359 Answers
Has to be clogged or frozen must get drain open or will shut down furnace
Posted on Dec 17, 2008
Why will the ac on my Coleman Evcon C.A.M.II not come on when the fan will work and the heat will work?
The a/c component is is dependent on water access. I am guessing there is a problem with the water connection. The cooling aspect is simply the fan pushing the air past cold water. If everything else is working, take off the front and see if anything is wrong with the connection.
Elisa Jed ' http://www.greenhippoplumbing.com/services/
Jun 24, 2014 | Coleman Heating & Cooling
We have a Coleman Evcon BW-305150. Last night we
There should be one right above the burner tray. Look at the wiring diagram (pasted on one of the panels) and follow the wires Usually red orange or yellow) to the switch (may look like a rectangle plate with 2 prongs) and jump the switch with a jumper to test.
Feb 26, 2010 | Coleman Propane Forced Air Heater...
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Freezer leaking water
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 09, 2008 | Freezers
Subzero 550 water drain in refrigerator section backs up
The problem is that the water freezes in the drain, either because the door is not sealing good, it's open too often or there is mold in the catching tray and tube. Best solution is to take a turkey baster (pump), disconnect the flexible tube from the tray, by pulling down, take a large cup with very hot water mixed with a spoon or 2 of Clorox, fill the baster with that mixture and pump it on the drain tube. You have to do it several times, water will come out, but do it until you hear a "woosh" sound and the water goes freely on the drain. Also spill some of that mixture in the tray so it kills the mold.
Apr 04, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice buildup
Apr 02, 2008 | Jenn-Air JCB2388G Side by Side...
Water in floor
Mar 26, 2008 | Refrigerators
Heating & Cooling Logo
103 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
