Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch wlf2260 I have a Bosch WLF 2260 washing machine which works well but it will not take the fabric softner, can anybody help. I have cleaned the detergent tray, checked that the pump is clear of debris, flushed the main waste pipe and cleared the drain hose pipe.
  • Anonymous Mar 20, 2014
    how long should the waste pipes be for this machine
I had the same problem, but had to take out the tray completely, strip out the top half of the tray where the water is injected to clean out the black gunge that was the blockage.
Posted on Mar 27, 2009
  • 5 Answers
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Posted on May 16, 2007
I've a Bosch avantixx washing machine and it won't empty the fabric softener unit. It has water left in or some softner. I've taken the tray out and cleaned it.
The softener unit is flushed between wash cycles to prevent clogging. What you are describing is normal operation.
Jul 12, 2016 | Bosch Washing Machines
My bosch classixx 1200 expressnot taking fabric softner
Okay first try removing the soap try and cleaning it,secondly get a jug of water and partly fill the softner tray, at this point it should automaticly drain if not then looks like the Solonoid coil valve is at fault quite easy to replace cost of parts around £20......Good luck, hope the first part solves this......
Feb 02, 2011 | Bosch Washing Machines
Bosch Logixx 8 Fabric conditioner not releasing into wash cycle
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2011 | Bosch Washing Machines
Bleach will not dispense
Here is a tip that I wrote about the problem I found with my fridgidaire not dispensing fabric softner. Hopefully this will help you out...
Fridgidaire Washing Machine Fabric Softner not going into washer
http://www.fixya.com/support/r5660917-fridgidaire_washing_machine_fabric
heatman101
Aug 20, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wlf2260
clean the detergent tray especially the part for the conditioner. on some bosch the rinse water valve is seperate uie different valve for water for main wsash. check valve is not open circuit resistance should be about 3.8k. could also be due to low water pressure
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Any ideas on cleaning where you put powder and fabric softer?
You can remove the tray by pusing in on the tab right behind the fabric softner compartment(on top). This would make cleaning very easy as you could take it and clean it right at the sink. Just make sure you don't over due it and wear out the tray.
Sep 07, 2006 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
305 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
