Question about Reddy Heater-30-55,000 BTU Variable
Won't run with top cover on
Runs with top cover off
It is lickly that when you put the top on that the top is creating a ground (completing the circuit) which means there is no spark created
Posted on Dec 13, 2008
Minka aire f608 top won't screw on
Check to make sure your blades screws are tight. They could be rubbing against the glass.
Jul 01, 2013 | Minka Aire Ceiling Fan
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
2002 clk 320 convertible top won't go down
Can you hear the convertible pump running at all when you hit the button. Most are hydronic. It might be low on fluid. Either that or check the relay
Aug 19, 2012 | Cars & Trucks
Why won't 1981 suzuki gs 550 bike won't start after riding it and it's warmed up?
hi
glad i served a long time with wisco and used drag raced for them at one time
sounds to me that your ignition is to far retarded
which means the ignition will spark closer to (TDC)
top dead center
some people advanced the ignition 3 deg to stop the engine from smoking when they did away with 4 star fuel
and gave us unleaded fuel
doing this the performance is great and fast acceleration
but it also make the engine run hotter than normal
unless you have up jetted the carbs
and fitted a non standard exhaust system
the whole idea is get the fuel/air mixture in and out as fast as possible
if you still have points
take your points cover off and adjust your points baseplate
undo the three screws that hold it in place
and just move it about 3 deg towards the rear of the engine
or may be you have a electronic ignition fitted
if so do the same thing
and advance the ignition 3 deg
hope this works for you
ride safe
Sep 18, 2017 | 1982 Suzuki Gs 550 L
2000 Mazda MPV Starts & runs won't go out of Park Shifter handle moves won't change gears??
I had this issue in the past. All I did was to replace the brake switch. This part is located behind the brake pedal. Btw, if you this run into this issue again in the future, you can always push this switch with your finger and it's located on top of your steering wheel enclosure, this will disengage the shifter.there is a small rectangle shape cover that you need to remove first.
Aug 08, 2017 | 2000 Mazda MPV
RayPac Pool heater won't light
check gas pressure too low it overheated replace fusible link on bottom after gas is fixed then clean heat exchange of soot
Apr 20, 2012 | Raypak 130,000 BTU Natural Gas Pool...
I hit rocks with my lawn mower on accident, and now it will run for a few seconds and turn off
This happens often. Sometimes your mower will start and run again and sometimes it won't. When it doesn't run it's because your timing is off, caused by a dented or sheared key.
To replace remove top cover to engine, and any other side attachments, this should expose the flywheel. Remove the top bolt and look between flywheel and top of crankshaft, you will see a small square notch. This is where the shear key is placed. Remove the flywheel and replace the shear key. Replace all parts in reverse order and you should be mowing again. GOOD LUCK.
Aug 31, 2011 | Poulan "Poulan" Push Mower
Talon engine has no spark
The engine timing is off. Did you hit something with your mower? Remove the top cover to your engine and any other attachments. You will see the flywheel. In between the flywheel and the top of the crankshaft is what is called the shear key. If this key is dented or completely sheared the engine won't run. This is why you have no spark . GOOD LUCK.
Jun 29, 2011 | Garden
I have white zero turn 54" lawn mower. The engine runs but the blades won't turn on. Please any advise will help
This is a belt adjustment problem. You machines belt has either broken, or is loose to the point where it won't engage the blades at all, or has just slipped off the pulley. I believe the belts are on top of the deck covered by removable covers that are bolted to the deck. Check and see. GOOD LUCK.
Jun 17, 2011 | Hawk 36" Red Hydro Walk Behind Lawn Mower...
Reddy Heater-30-55,000 BTU Variable Logo
108 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
