Question about Sennheiser BW900 Bluetooth Headset
Answers home phone, handset lifter works fine, but no voice heard
BW900 pairs with Voice Recognition, with cellphone and with base station just fine. Works speaking into Voice Recognition, cell phone just fine. When home phone rings I hear ring in headset, I push button and it answers fine, handset lifter works fine. But no voice comes through. I called the supplier and they said others are having same problem so they sent me a new unit and it does the same. Please help!♦
  • 734 Answers
Please go to the following link to find your answer =
http://bw900source.com/?cat=3
Thanks
Posted on Dec 13, 2008
  • 1 more comment
  • futureloginn
    futureloginn Dec 13, 2008
    Upon delivery, the headset and the base station are already paired. You can pair the headset to either a mobile phone or a similar device with a Bluetooth “handsfree” or “headset” profile.Once you have paired and connected to a Bluetooth device, the headset will remember this setting and automatically try to connect to the last
  • futureloginn
    the above post is for reseting the  BW900 Bluetooth Headset----'
  • futureloginn
    How to re-pair and reset the BW 900 system
    Pair the BW 900 headset with the BW 900 base station by doing the following procedure: *
    On BW 900 headset - Press and hold down both hook and multi switch untill LED blink red/blue
    On BW 900 base station - double quick push the PRG-button on the side behind the steel lid until the LED on the front blink red/blue
    Both the headset and base station will confirm the pairing by a double blink blue from the LED's.
    * This will also bring the BW 900 office system back to its original setting for all sound adaptive intelligence.
    hope helpful
    THANKS
  • 13,433 Answers
Try reconnecting the bluetooth handset again,  Can you tell me what phone are you using it with? and I can look into it more Thanks.
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Lands Phones
When programing our incoming phone message this is a lot of static on the message which makes the message hard to hear. How do we correct this issue?
Cordless land line phone:
  • If it is possible to set the greeting from the base speaker phone, use that.
  • If the base does not have a VOX speaker, move the handset and the base away from anything that emits elelctro magnetic RF...like wifi access points, microwaves, etc and set the greeting.
Cell Phone:
  • Avoid using the handset to set the voice greeting unless your handset supports a visual voicemail service that captures the audio greeting first and then sends the audio file over the IP.
  • Call your cellphone# from a landline, hit # or * and your PIN, and access the greeting menu from there.
  • If your cellphone and carrier support Wifi calls, VoLTE or Packet switched voice service, set your handset up for hat feature. On an iPhone it looks like this:
Sep 04, 2015 | Lands Phones
Is BW 900 Sennheiser compatible with Windows 7?
according to Sennheiser, it depends on the compatibility of the usb device driver of your bluetooth adapter in Win7 (it is NOT a BW900 problem in their opinion)
as I understand it, you have therefore to by a new adapter and see whether it works with the BW900. Take the device AND your computer to the shop and have them install and pair
Sep 06, 2010 | Sennheiser BW900 Bluetooth Headset
New voice mail
This is a cordless extention phone "its base station" must have a answering machine correct?
Well you need to check you messeages on that and clear them out on that and this phone would be cleared as well, if you do not have a base station with a answering machine or voicemail system then your phone company must have one and there sednign these messages down the line to indicate someone left a voice mail on the syste,
Ether or here you did not tell me about the rest of the system so I am cought assuming that is what it is because it is what it is somewhere down the line you have a voice mail ether on a home based system or your telephone company.
Thanks please do not forget to rate. Thanks
Jul 02, 2010 | Panasonic KX-TGA101S Cordless Handset
How do you unregister a defective handset so that it can replaced
1. Delete or listen to all voice mail messages, if necessary, to clear the IN USE/Voice Mail light indicator.
Note: Skip this step if it does not apply to your MD Series cordless telephone model.
2. Press OFF on the base station and each handset.
3. Press and hold down PAGE on the base station until the IN USE light flashes slowly, then release.
4. Press and hold down PAGE again until the IN USE light begins to flash quickly, then release PAGE.
5. Quickly and fully press and release PAGE again.
6. Please register handset displays. Press OK to begin the registration process, or press EXIT.
Dec 10, 2008 | Motorola Mobility MD41 Expandable Handset...
Vtech not working
Have you tried putting in freshly charged batteries and registering the handsets to the base station?
May 01, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Displays new voice mail and VMWI constantly blinking when no voice mail
Subscriber is T-Mobile@Home. First, cleared all messages from T-Mobile voicemail.
Now to fix your GE phone:
Push the program key. Select Handset Setup Push the program key Select Default Settings Push the program key Select 1 Yes. Push the program key
Hope this helps.
Mar 06, 2008 | Uniden Cordless Phone
I have a phone from Vtech
Having researched this phone, the message feature you have is voicemail. The machine itself does not have an answering machine in or on it. First make sure that you have voicemail through vonage. And check with them that the voicemail notification that they provide is compatable with the Vtech phone. Next try these steps Tip 1 of 7 Your phone is designed to work with most local and regional telephone service providers? voice mail systems. Voice mail (also known as voice messaging) is a subscription service, available from most service providers for a fee. This feature does not work in conjunction with your home answering device. Contact your local telephone company for more information about their voice messaging system. Tip 2 of 7 Your voicemail feature is compatible with both stutter and FSK signals from your local phone service provider. Contact your service provider to ensure you are receiving one or both of these signals. Tip 3 of 7 Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the VOICEMAIL light on the base is flashing in the presence of unheard messages, however your handset does not display MESSAGE WAITING, it is likely your handet is out of range from the base. Tip 4 of 7 Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices. Tip 5 of 7 The VOICEMAIL light on the base will flash and MESSAGE WAITING will be displayed on the handset only if there new, unheard messages. Once all new messages are heard and the phone is returned to the idle (OFF) mode, these indicators will be turned off. Tip 6 of 7 If the handset is not responding normally, you may need to reset your telephone system. Complete the following steps to reset the telephone system: Step 1: Disconnect the power to the telephone base. Step 2: Disconnect the handset battery. Step 3: Wait a few minutes and then reconnect the power to the telephone base. Step 4: Reconnect the handset battery Step 5: Wait about one minute for the handset to re-establish a link with the telephone base and then test the phone again. Tip 7 of 7 If the other phones in your home are having the issue, the problem could be related to the telephone wiring in your home, or with your local telephone service. Please call your service provider for further assistance. If this does not help, repost with further info. Please rate this solution throigh fix-it. Thank you
Jul 02, 2007 | Vtech ia5823 Cordless Phone
Sennheiser BW900 Bluetooth Headset Logo
76 people viewed this question
Top Sennheiser Radio Communications Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Sennheiser Radio Communication Expert? Answer questions, earn points and help others
