F 22 code
I just had a Whirlpool Duet Diamond Dust front load washer delivered YESTERDAY after being without a machine for close to 3 months. Did the first load just fine however I am not getting a F 22 error message. I have tried everything the troubleshooting guide suggested; can't get the door to open, even after unplugging the machine. I have tried changing from a normal wash to a heavy wash....nothing. When I press power and start, I can hear a clicking noise.
  • rclayton Dec 30, 2008
    My Kenmore HE2Plus also has the F-22 err/code problem. This is the second time in the 1.5 years we have owned this washer. Last time they replaced the controller board. It is acting the same way... it won't go into spin cycle and the door won't open. I can hear the door relay clicking, but it won't go into the spin cycle.
    Is there a recall on this? Twice in less than two years is not right.
  • 333 Answers
It sounds like a faulty power board. This board controls all the functions of the machine. Youe best solution is to call the company where you bought it and thell them the problem and let them send a technician
Posted on Dec 13, 2008
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I test my whirlpool duet? There are certain buttons you push and I lost the instructions can anyone help
are you trying to run diagnostics?With the machine off, hit any button (other than pause/cancel) hold it for 3 seconds, let off for 3 seconds. repeat 5 times or until machine comes on.
Nov 08, 2009 | Whirlpool WHP1500SU 15.5" Diamond Dust...
Duet washer deliv yesterday start button won't work.
delivered yesterday??? call back the dealer and have them send out a repairman/ or replace the unit you didnt pay for a brand new unit to be reapired
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22 code machine won't work! What now?
F-22 USUALLY MEANS LONG DRAIN,,IF IM NOT MISTAKEN,, REMOVE BOTTOM 3 SCREWS FROM PANEL ,U SHOULD SEE PUMP .,, REMOVE CLOCKWISE AND CLEA OUT PUMP,, JUST REMEMBER STILL HAS ABOUT 3 GALLONS OF WATER EVEN THOUGH LOOKS EMPTY
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have a whirlpool duet front loader washing machine and the error code I am getting is F 28. We just had the repair guy out yesterday, can you help me with this. What is the code for?
The code is for either the MCU (Motor Control Unit ) or the CCU(Microcomputer Machine Control Unit), U probably need to rplace one of them
Good luck
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
87 people viewed this question
Top Washing Machines Experts
