Question about Sony KP-46S25 TV
SONY KP-46S25 I have am looking at purchasing a used 46'' sony television and was wondering if someone could tell me about the horizontal lines on the screen. I have been told it might be the v-hold and that it could cost 300.00 to fix. I would purchase this television for 100.00 just wondering if anyone would know what might be the problem with it. It has lines that go across the screen only seen when up close but far away does not appear to be seen . thanks in advance for any help given
    Novelist:
    Champion:
  • 236 Answers
A "Gray Scale" adjustment may solve you problem. If one of the picture tubes is set too high it will cause these RETRACE lines. Then too a weak picture tube might cause this. If the horizontal lines are one color: red, green,or blue then whichever color that is shown would tell you which tube is set too high. Your set has 3 screen controls that control the brightness of each tube. One may need to be turned down a little. Stargazer
Posted on Mar 11, 2007
I have a Sony KP-46S25. The screen is cracked. I
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Dan
Apr 08, 2010 | Sony KP-46S25 TV
My Sony KP-46S25 TV is blinking red light and is not turning on, please advise.
Please update this with the blink count. The standby light shouldbe blinking a repeated count with a pause. This will indicate the problem circuit and allow me to provide you with the probable defective part(s).
Thanks,
Dan
Jan 07, 2009 | Sony KP-46S25 TV
Kp-46wt500
the pico fuse are the two little yellow resistor looking things under the heat fins of the convergence chips
Jan 03, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue Horizontal arching lines, Blue hue at power on
if you take the front cover off the tv, you will see 6 little nobe, the top 3 are focus, bottom 3 are brightness, should be RED-BLUE-GREEN in order from left to right, find the one that is blue, turn it down a quarter turn, should fix the problem
Dec 31, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-46S25
You have to find the reason why the fuse is blowing. to do that you have to open the up the TV anyway. try another fuse and see if it burns. fuses blow because there is more current going through it than the fuse amperage can hold. it is probably a burnt resistor.
Nov 28, 2008 | Sony KP-46S25 TV
FOGGY COLOR
Sure, you can fine service menu with universal remote control. Just find properly code number for Sony tv.
Aug 11, 2008 | Sony KP-46S25 TV
Sony Television
If model # is KP-46S25, red CRT is probably bad...have it checked by a qualified Sony tech......................T.
Jan 07, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46S25
I don't think so it's curves in.
Dec 05, 2007 | Sony KP-46S25 TV
Sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Mar 28, 2007 | Sony KP-46S25 TV
Tracking???
If everything else is fine-then the set needs to have the picture size adjusted. Sometimes this happens when there is a power spike. Otherwise you either have a voltage reduction on the curcit the set is plugged into, or your house. Or the power supply is gowing and not putting out enough juice to the set.
Dec 17, 2006 | Sony KP-46S25 TV
Televison & Video Logo
123 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
