Question about IBM ThinkPad T60 Notebook
PROBLEM WITH T60 IBM THINKPAD
I have a IBM T60 1951A24 , WHEN I SWITCHED ON MY SYSTEM IT GEVEN AN ERROR CHECK DATE TIME SETTING AND SYSTEM SEQURITY -THE SYSTEM HAS BEEN TEMPERD WITH, THEN IT DISPLSY SA SYMBLE WITH LOOKED. SUGGEST ME
  • Anonymous Oct 09, 2008
    same locked up tight
    Novelist:
  • 198 Answers
If your laptop received a password protection and that password was forgotten there is no user manageble way to recover or disable the password. Maybe the person who tampered with it tried to reset the BIOS by removing the battery or things like that. They woun't work as the password is stored in a NAND ROM memory section of the BIOS, meaning that it isn't volatile and can't be erased like PC's BIOS by removing the power and battery. If you can't modify BIOS settings or you can't get rid of the "locked" display image, you need to go to a service center to have the password removed by them. This operation requires BIOS flashing and can't be done by the normal user as it involves specialised hardware. Sorry for I can't assist you further with a easy fix or something like that.
Posted on Mar 14, 2007
Games not play on my IBM ThinkPad T60
check graphic card.if ur system lacks it the games will not run.
minimum 512mb graphic card is req to run todays games smoothly.
or may be ur system is old that dosent support todays games.
Dec 02, 2012 | Systemax IBM ThinkPad T60 Notebook PC T60...
Error 00161 and 00163 on my IBM Thinkpad 770
Please find below the error on your laptop, i read it on other forum and it says that error 161 is a dead battery while 163 is a timer that was not been set properly.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
163
(Time and date were not set.) 1. Set time and date.
2. System board.
Numeric error codes index - ThinkPad 600/E/X
hope it helps..
Aug 23, 2011 | Computers & Internet
I have 0271 error can get into bios but not able to change the date and time??
The error means that you have to change the BIOS battery first before trying to change the date and time.
As far as i know with IBM's the CMOS (RTC) battery is located under one of the panels underneath the laptop and is usually covered with red, blue or yellow plastic with wires coming from it. Disconnect the battery and replace it
Once the CMOS battery is replaced you can set the date and time and no more error messages.
Regards.
Jan 24, 2010 | IBM ThinkPad T60 Notebook
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
What is error 00173, 00192, and 00163
Error 192 means a fan error, to test this measure the voltage of the backup battery. If the
voltage is not correct, replace the backup battery. Check the fan and the system board.
Error 163 means the time and date is not set, to set the time and date hit F1 when you see the IBM logo and set the time and date.
Error 173 means the configuration data is lost, to sort that select OK in the error screen and set the time and date.
In most case its the CMOS battery that's run low and need to be changed for a new one, so for the time being you will have to keep setting the time and date and it will boot to windows.
Good luck
Jun 15, 2009 | IBM Thinkpad 600 System Board Motherboard
My IBM Thinkpad is not switching on?
The error message relates to the date and time setting in the BIOS, it has a wrong due to a flat BIOS battery. The needs to be replaced and the date and time corrected,
The padlock symbol indicates the laptop's BIOS has been set with a password and you cannot enter and change the BIOS settings without this password.
Replace the BIOS battery with a new one, then boot up and enter your BIOS password, then change the time & date, then save and exit.
Mar 15, 2009 | IBM ThinkPad T21 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the voltage is not
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM Think pad T21 Notebook can not boot!! Help please
Run IBM BIOS Setup
Jul 17, 2008 | IBM ThinkPad T21 Notebook
ERROR 0271
Are you a computer whizz? (do you know a lot about computers like me?)
Could be the Cpu fan (Central Processing Unit)
That could be lethal to the laptop.
Just as well it's a IBM other wise . . .
As for the error it means the time and date are not set.
soloution: run the bios setup utillity to reset time and date.
1358
Jun 25, 2008 | Acer Aspire 5610-4648 Notebook
IBM ThinkPad T60 Notebook Logo
383 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
