Question about Ovens
Frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The oven temperature does not remain constant. Usually higher than the setting on the knob but it will not stay at the same temperature while cooking. For this model you cannot adjust the temperature by changing the back of the temperature control knob. Do I need a new thermostat?
Thank you
Bob
  • Ovens Master
  • 3,463 Answers
The short and simple answer is yes you do.
Posted on Dec 14, 2008
Oven overheats. It doesn't matter to the temperature you set it. The oven temperature goes higher.
The first thing to look for is the temperature probe inside the oven. If it is bent and touching the side of the oven, the oven wall will cool the probe, and the oven will always be to hot.
Then next answers depend on the vintage of the oven.
If the oven always runs 20? hot (for example) it is possible to adjust the set point on older ovens by removing the oven temperature setting knob and by using a long thin screw driver through the centre of the shaft to adjust the oven temperature to match the oven setting. You will need to buy or borrow an oven thermometer.
May 06, 2016 | Ovens
Frigidaire oven overheating
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
Feb 12, 2014 | Frigidaire Ovens
Oven runs much hotter than set temperature. Usually 50 degrees hotter than what it is set at, but can go over 100 degrees higher.
Sounds like you need a new oven thermostat or get an oven thermometer and by experimentation draw up a new heating range for the oven dial.
Feb 11, 2011 | Frigidaire Ovens
Takes long to reach it's temperature
Hello there
Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 09, 2010 | Fisher and Paykel OS302SS, Stainless Steel...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Slef cleaning oven Frigidaire electri clean oven lock will not un
set both start & stop timers to the same time.Turn on the selector and the temperature knobs to clean. Hold in the light button, on the right top side of oven, and hold for 15 seconds.
then turn off the selector knob. hold button again for 15 seconds and the lock should unlock,
then turn off the temperature knob.
Jan 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
163 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
