Question about Jensen KDC-9520 CD / Cassette Player
Receiving error 8 message
When I put an CD in I get an error 8 message and the CD does not play.
My Technic SPD967 is not working. Whenever I put a cd in the tray and press the play button, I am getting an E message.
"E" must stand for error, either the laser decoder is faulty or the cd motor is not spinning or the laser is dirty or faulty, more investigation needed
Jun 28, 2014 | Technics SL-PD887 5-Disc CD Changer
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
Getting disc error when cd is present.
The problem is in the laser pickup assembly, buy a CD cleaning kit and follow instructions, If that fails! it must go back to Bose for sevice the only way.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
When i start my pc it display NTLDR file missing
Here ya go!
http://www.tinyempire.com/notes/ntldrismissing.htm
Jun 14, 2011 | Computers & Internet
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Put a CD in and get message that says ER (Error?)...every CD that goes in spins, but does not play.
could be one of 2 things
use a cd lens cleaner to clean the laser lens .
or could be warped or damaged cds and player wont play them
also if they are burnt cd the player may be to old to read them.
Apr 26, 2009 | Audio Players & Recorders
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 17, 2008 | LG Televison & Video
LineOut
Yep. Take it to the nearest Sony Repair facility, usually when they say that there in an internal problem with the audio in from the laser to the audio ic
Don
Jan 02, 2008 | Sony CDX-R3000 CD Player
ON THE SCREEN IT SAYS "FAULT 8"
I am receiving the same error. How do you fix the Fault 8 error? It is not listed in the book..
Aug 16, 2007 | Jura Capresso F8 Espresso Machine
The CD has quit playing and an ER 4 message
I had it too. - when I bought the used vehicle and was elated that it had a Jensen sound system in it. The sound was good - played a CD the first time I put it in. We listened to the radio after an hour and then attempted to replay the same CD. The ER-4 message showed up. The man who sold me the vehicle had given me the paperwork on the unit and I reset it. I've had to do this at least 4 times which means you have to reset all your favorite stations, time, etc.
Nov 29, 2005 | Jensen KDC-9520 CD / Cassette Player
Jensen KDC-9520 CD / Cassette Player Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
