Question about Scytek 2000RS Remote Control
Galaxy 2000RS-M not working
After short periods of use the remote stops working. I do not have the manual and can't re-set the remote. Not light comes on when I press any of the buttons.
  • 366 Answers
Sounds like a defective remote, you can find new remotes for the starter on ebay ,
the manual can be downloaded from scytek.net
Posted on Oct 11, 2009
I need the manual for this unit. (I recently had
Click HERE to download user manual copy of Galaxy 2000RS
Hope this will help you.
Thanks.
Dec 12, 2009 | 2000RS-M Remote Starters Manual...
Don't know how it works.
manual for the system can be found at scytek.net
Apr 30, 2009 | Scytek 2000RS Remote Control
The doors lock when I start the car - I don't want that!
the unit can be programmed to lock the doors after starting, to make it leave it alone you have to enter the programming(ignition on, press the valet switch 5 times within 5 seconds, the lights will flash 3 times to signal you have entered programming, then press valet switch 10 times(lock after start setting) within 5 seconds hit the unlock button on the remote (button closest to the side with the other buttons)
then turn off the ignition to save the settings and it should be done
manual for the system is found at scytek.net under the download section
Apr 14, 2009 | Scytek 2000RS Remote Control
Galaxy remote start wont do anything.
i just fixed mine.. under your dash look for the immobilizer switch box/plug...the red light should be lit, unplug then plug back up again (reset it)...you should be fine after that.
Mar 09, 2009 | Scytek 2000RS-M Remote Control
Timer in auto start.
if it is the 2000 rs the manual can be downloaded from scytek.net
1. Turn on ignition.
2. Within 5 seconds, press the valet switch 5 times.
· The parking lights will provide three blinks, indicating that you have entered Programming.
3. Press the valet switch 12 times (engine run time)
· The parking lights will flash each time the valet switch is pressed.
4. Within 5 seconds, press the transmitter button corresponding to the desired time ( left button 15 min, right button 25 min)
· The parking lights will flash to indicate the setting.
1 flash = 15 min
2 flashes = 25 min
5. When you are finished, turn off the ignition to save the changes.
all of this is based on that it is the galaxy 2000rs m,
Nov 19, 2008 | Scytek 2000RS-M Remote Control
Galaxy 2000 Rs-m
yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
May 26, 2008 | Scytek 2000RS-M Remote Control
Car Alarm Instructions
go to scytek.com you can download there
May 15, 2008 | Scytek 2000RS Remote Control
Galaxy 2100RS
if this vehicle has a white wire in the ignition harness it needs powered by the ignition out of the remote start if your remote start doesnt have a second ignition use relay not poering this wire will ruin your transmission the white wire must have power this should solve your problem dont use remote start until you fix this problem or it will cost alot of money.
Mar 13, 2008 | Scytek 2000RS Remote Control
Auto start
did you install yourself and what module did you use for the doorlocks or did you have it installed at a shop
Sep 26, 2007 | Scytek 2000RS Remote Control
Scytek 2000RS Remote Control Logo
409 people viewed this question
Top Scytek Televison & Video Experts
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
