Question about Lands Phones
RCA phone 25205RE1-A System answer problem
System does not answer or provide any default answer or personal message recording. I have gone through the programing several times with the same result. I can set # of rings to answer but phone simply stops at the preset #
Any idea?
Harold
SOURCE: How do I record my own message for the answering machine?
1. Press and hold down the announce button.
2. You will hear record announcement after the tone.
3. Once you hear record announcement after the tone continue holding the relase button and record your message.
4. When you are done recording release the release button.
5. To hear your recorded message press and hold the release button and release after you have heard your message.
6. If you are not pleased with your recorded message, repeat the steps obove.
Posted on Jan 17, 2008
SOURCE: IIncreasing the number of times the phone rings before message system answers
I have a Panasonic KX-TG5632 and I need to set the ring time, how do I set the ring time?
Posted on Jun 10, 2008
SOURCE: RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Posted on Dec 03, 2008
SOURCE: RCA 25205 Visys will not record message
Melissa is correct about the manual being wrong. You have to press the Sel/Save button, not the Exit button after recording a personal message. Then you have to follow the directions on page 23 to Configure each line to Personal Message.
Posted on Mar 27, 2009
SOURCE: cannot record new answer phone message
push the mute button on your cordless uniden phone,and you will see the number 5 come up on the phone display.then hit the number 6 and when you hear it begin to beep record your message
Posted on Sep 14, 2010
How do i set the answering system on a uniden 1580-3 phone, mine is just background noise on the answering machine when someone calls in to leave a message
Here is the manual for your phone. You can download the manual and the instructions for setting up your answering machine are on page 43:
http://www.uniden.com/pdf/DECT1580-3om.pdf
Setting Up the Answering System
You can set up your answering system's features from the handset. Only one handset at a time can access the answering system menus.
Note: If you have multiple bases, select the base with answering system you want to access (see page 15).
Recording a Personal Greeting
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: "Hello, no one is available to take your call. Please leave a message after the tone." You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement.
When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting
Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can
also switch back and forth between the pre-recorded greeting and your own greeting at any time.
Press 6. The system plays the current greeting.
Jun 15, 2011 | Uniden 5.8GHz Expandable Cordless Phone...
I can record an OGA, but when people call they get the automated default message. How can I set the OGA so that it replaces the default message?
Once you record your own message, it replaces the default one. If callers are still getting a different announcement, it's likely they aren't ever reaching your machine. Make sure that your telephone line voicemail service isn't picking up the calls instead. I've known several people with this same trouble, and they needed to modify their home voicemail (or whatever your service provider calls theirs) settings or turn it off. Then their phone answering machines worked properly.
Jan 01, 2011 | RCA 25250RE1 2-Line Cordless Phone
Can't turn off the answering machine on the RCA 25205
it is simple. press menu and hold and it will most likely give you directions, step by-step. there should be on/off switch
Jul 31, 2009 | RCA 25205RE1 Phone
Oct 27, 2008 | RCA 25205RE1 Phone
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
RCA 25205 2-line corded pnone answering machine won't answer
Record the message for both line one and line 2, see if that helps.
Sep 03, 2008 | Lands Phones
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
My new RCA Model 25205RE1-1 1815MO does not want to record a OGA. It appears to be recording as it so states and counts the seconds as you are speaking. I press EXIT and the OGA is not played...
The RCA Manual in incorrect. Step 8 reads "Press Set/Save to start recording. Speak within 6 inches away from the Mic located under SPEAKER button." Step 9 reads "Press EXIT to stop recording." Step 10 reads "The OGA is played automatically for your verification. It will then return to the OGA REC menu to start over or to record another OGA."
Step 9 should read "Press Set/Save to stop recording and the OGA is played automatically for your verification."
Step 10 should read "Press EXIT if recording is acceptable. Press Set/Save if you want to re-record."
By following the Manual you never save your message. "Playback" always has the Default message that comes on the machine. Furthermore, Customer Service at 310-953-9028 doesn't have a clue.
Jul 01, 2008 | RCA Lands Phones
Help! Re-recording message
Following are instructions for the GE25881 phone which is similar to your 25880. Hopefully this will work for you. -Vish Answering System Set Up This section shows you how to set up your answering system to receive incoming calls. Before you begin the setup, you must turn on the answering system. ? Press the conference/ans on/off button to turn the answering system on and off. NOTE: The display shows ANSWERER OFF when the answering system is off. The default status is on. Voice Instructions If you need additional assistance, press and hold the memo button on the base and follow the voice instructions. 12 Answering System Operation Recording the Outgoing Announcement For best results when recording, you should be about nine inches from the microphone, and eliminate as much background noise as possible. 1. Make sure the answering system is ON. 2 . Press and hold the announce button on the base while you record the announcement. 3. Begin speaking after you hear the beep. 4. Release the button after you finish your announcement. If you choose not to record an outgoing announcement, the default announcement plays. To return to the default announcement after you have recorded your personal announcement, press the delete button on the base while playing the announcement, or press the announce button and release it when you hear the beep.
Jul 23, 2007 | GE 25880 Twin Phone
Lands Phones Logo
121 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
