Question about Motorola Mobility RAZR V3
Razr Master Reset
I was giving my razr phone to my son, and to clear all my contacts vice doing them one at a time, I did a master reset. Now the only button that works is the End button. Any suggestions? I have tried taking the battery out for 30 minutes and trying again, no luck. Thanks. Natick
From non expert here but I'd say that a master reset not only removes contacts but you have to get serial id's etc out of the back of the handset and call your service provider to reprogram the handset fon number and other details back into your fon. just a first guess but i didn't see any one else answering so i thought i'd throw that one by ya! (No Extra Charge) lol.
Posted on Mar 23, 2007
SOURCE:
I have a T-Mobile Motorola Razr V3. I want to give the phone to "Cell Phones for Troops" program. I want to ensure everything is erased off the phone but I do not have a SIM Card anymore so I can...
You do have to have a SIM card in the phone to do the Master Reset/Master clear. If you take it to the nearest AT&T store they should be able to put a SIM card in it long enough to do a master reset for you!
Dec 06, 2010 | Motorola Mobility RAZR V3
Phone gets hanged
Hai Dud,
You can do it but u can't format as in PC's u can reset the set as:
1.Back up ur contacts & other related items u needed.
2.Then Click on "Settings"
3.Initail Set up,scroll down u can chose Master reset or Master Clear.
4. Better go for Master Clear.Now everything is cleared from ur hand-set.
Hope it Helped You,If so give an "High Five!" [;)]
Jul 18, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Lost unlock code
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3:
1. Open your phone up and go to “Settings”
2. Next go to the selection for “Initial Setup”
3. Next go to the selection for “Master Clear”
4. Then select to confirm the option.
5. Now enter the security code which should be “000000”
6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post:
hard reset motorolla razr v3
hard reset razr phone
wii master reset
hard reboot motorazr
how to hard reset a razor v3
master reset code for motorola v3
master reset code razr v3
master reset for v3 via pc
master reset motorola razr 2
master reset v3 razr with white screen
motorola v3m master reset
p2k commander
razor master reset
razr 3 and how to reset
razr master reset ebay
razr master reset password
razr master restart
razr screen master reset
reset razr
reset razr to factory
reset razr v3 to factory
v3 hard reset razr
v3 razr reset hard boot
Jun 14, 2009 | Motorola Mobility RAZR V3
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
How do you do a master reset
my razor v3c is having issues where the screen is backwards any one have an idea on how to fix this
Jul 21, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Gets cut every time when i am making a call or reciving a call
Try making a Master Reset and a Master Clear of the phone, to do that, go to Menu, Settings, Initial Setup, Master Reset.
May 03, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3m freezes when I text
do the master reset and master clear it should do the trick!
i have the same problem as you do, before.
default security code is 000000
Jan 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr Master Reset
Perhaps a keypad malfunction? their is solved problems for that if so, or a software problem not sure.
Mar 11, 2007 | Motorola Mobility RAZR V3
Razr V3m Cell Phone
dear first clean the contents with ctc if not ok open the phone un plug the connector and then again connect it and check.
Motorola Mobility RAZR V3 Logo
307 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
