Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Down travel I installed the new opener and I can't get it to stay down. I made adjustments in the travel and adjustment screws on the lt side up/down and still not working. Travels up great.
  • 1 more comment
  • Anonymous Jan 07, 2009
    same
  • Vince Heuser May 11, 2010
    Are the safety eye lights on? What is down force setting on?
  • Anonymous Mar 13, 2014
    there is no adjustment screw in site any were on this unit
  • 504 Answers
HOW DOES THE DOOR WORK WHEN NOT CONNECTED??
DOES THE OPENER GO DOWN WHEN NOT CONNECTED??
ARE THE EYES ALIGNED CORRECTLY?? DO THEY MOVE OUT OF ALIGNMENT WHEN THE DOOR CLOSES??
IF THE DOOR IS NOT HARD TO CLOSE -DOWNLOAD THE INSTRUCTION MANUAL AND FOLLOW THE ADJUSTMENT INSTRUCTIONS CAREFULLY.
HOPE THIS HELPS
Posted on Jun 17, 2010
Door opens itselv after closing
most likely the down stop is set to low, the door hits ground and reverses. so either change the down stop position or increase the down force so it will not reverse upon contact.
Dec 06, 2015 | Building Materials
We have installed the craftsman garage door opener and have continually adjusted the up and down travel limits and the door will not stay down
try adjusting the down force. the force necessary to may it reverse. it may be set too light. increase the down force and see if that helps. usually screw in back of unit. and usually labeled.
Jul 24, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
I have a Master Mechanic garage door opener. The door will only go up and down a certain distance. Is there a chain travel control or set. All chains have been lubricated.
There is something called limit switch adjustments. They should be on the side of the opener. If the opener is not going up fully, increase the up limit by turning the up screw. Use a flat head screw driver only. 1 full turn of the screw gives you 2in of travel. Same for the down. If the door is not going down fully increase the down limit by turning the screw.
Oct 10, 2013 | Craft Master 300 Mechanical Sewing Machine
I have Sears Craftman 1/2 HP garage door open that want stay shut when you push the remote the sensor wire broke fix that. Now the door goes down and come back up. All sensor are led light are green...
Check the sensors again. Our unit has one amber and one green when working and if something (even a weed) breaks the optical beam it reverses and the lights blink. We've also had bright sunlight interrupt the beam. (The test for this issue is to stand such that you cast a shadow onto the sensor without being in the beam and then attempt to close the door with the remote). Next check if the door is binding during travel. If it is, check the tracks for plumb with a level and make sure the door rollers and tracks are undamaged. If a rail is crimped anywhere, it could be cause the problem. You can find some garage door sales places that sell the track sections and rollers to replace damaged parts. Check your local phone book and call around. In some cases, the door jamb may be damaged (lowering the header and shrinking the entire door area). This may require calling a professional to fix.
If the door itself is moving easily, then it sounds like the door might be hitting the floor too lightly or trying to go past the floor and triggering a safety reverse. On most of the openers, there are several adjustments you can work on to reset this. First try adjusting the down limit to above the floor and then bring it back to the floor. (However, usually these do not make the opener light blink.)
Alternatively, adjust the downward force to a higher value.
Without knowing the model of your Craftsman opener, I'll just use the directions for mine. All of these are adjusted with a flat blade screwdriver. Always test each adjustment with a complete up and down cycle.
The height limit control is on the side. (It's the forward one of two screws inside the cover - you should be able to reach them thtrough holes in the cover. Unfortunately, sometimes it's easier to get to them after removing the cover. The cover is held by 4 screws - 2 on each side.) To decrease the travel, turn the Down screw clockwise. One full turn of the screw is 2" of door travel.
The force controls are on the back with the down adjustment on the right. Turn this clockwise in 10 degree increments and test each time.
It is possible to overheat the opener with too many open and close cycles. In that case stop adjusting the unit and wait 15 minutes for it to cool.
I hope this helps.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
No matter when i adjust the force the door goes down, stops briefely, them returns to open position. can't get force adjust to let it stay down.
If the door is hitting the floor and then reversing it is traveling too far in the down direction. Locate the 'down limit' on the side of the motor unit and turn it in the opposite direction of the arrow printed on the cover. Some tweaking of this control will be necessary to get the travel just right. The force adjustment affects the safety of your opener. Try to put it back where it was.
Sep 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
How can I udjust garage door so that will close all the way down to the floor? Sears 41A43157 ? It came with the house - previous owner had no instruction manual. It was installed in 1993. Otherwise works...
look for 2 plastic screws, should be white in color. the screw on the left adjusts the down travel. there should be arrows pointing to which way to increase the travel(i think turning left for down). if you only need a few inches to reach the floor you should be able to adjust. if its way off there may not be enough adjustment. 1 full turn will move will door a couple inches so adjust a little at a time or you may overshoot. good luck
Apr 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens about 1 foot too far, the use of the travel up screw either appears to do nothing or it does too much when adjusted. How do you know how many inches the screw is affecting in a turn (or partial...
Are you turning travel screw, or force screw? If travel, One is for how far up and other is for how far down. Insert screwdriver into UP adjustement and turn it opposite direction of arrow. Try 2-3 turns to start. Yu may have to turn back CW. If while adjusting door just stops, go have a cup of coffee. You overheated motor. Give it 15 minutes to cool down.
Dec 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can the travel limits on a Chamberlain security+ be reset?
If you are at the back of the operator looking toward the door the limit adjustment should be on the left hand side.
The adjustment closest to the door is the down limit turn that 3 turns clockwise. The adjustment screw furthest from the door is the up limit turn this screw 3 turns counterclockwise. That should get you close to factor settings. If this does not work; remove the cover on the operator sometimes the limit assy. come apart.
Oct 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Companion II Scooter
Need to remove the five screws form the back side of the tiller. You can then tell if the adjustment lever has come off or the adjustment cylinder is bad.
Sep 21, 2008 | Golden Technologies Companion II Travel...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
78 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
