On this website you find fuse box description for Hyundai Elantra (2008)
http://www.autogenius.info/hyundai-elantra-2008-2009-fuse-box-diagram
SOURCE: location of oil filter on a 2008 hyundai elantra
It is located under the alternator. If you are looking down at the engine, it is to the far left. If you are under the car it is to the far right before the oil pan.
SOURCE: The radio and cigarette lighter have both lost
Many (= not all) fuse boxes have a chart molded into the case and the fuses can nearly always inspected visually to see if the fuse element is intact. The one that services those items is probably marked as 'accessories.'
SOURCE: need power window diagram for 2000 hyundai elantra
is this what your looking for??
Front Door Glass:
SOURCE: How many quarts of oil will the 2008 Hyundai Elantra hold?
Does the book say 6 quarts? I would put in 5, then run it, then let it settle for a couple minutes, then check it again. The book should be right. That would probably include changing the filter also.
SOURCE: heater quit working 2001 Hyundai Elantra. Checked
If the heater is blowing cold air, it could be your thermostat. They cost $20-50 at an auto parts store. Also, after the car has been ran for awhile does it come up and stay at normal operating temperature? Is your coolant level normal? If the car is high in mileage and the cooling system has never beeen flushed, it may just need flushed.
