Question about 3Com 2250 Plus (3C16476CS) 48-Port Ethernet Switch
I can not log in to 3com switch 2250 exept after restart
  • ivm_ivanov Feb 16, 2009
    I have 3com 2250 48-ports switch.
    I can't connect to the web interface using its default IP address 169.254.219.129. I'm setting up IP addres of my computer to be in the same subnet, for example 169.254.219.120 , subnet mask 255.255.255.0 and type in the Internet Explorer address bar the address ot the switchhttp://169.254.219.129. No response.
    I tried to connect via com port, but the result was the same. I used COM2 ant Hyper terminal on the computer running Windows NT 4.0, speed 38400, data bits 8, stop bit 1, parity - none, flow control - none.
    What wrong with me or with my switch?
Switch powers off
  1. Faulty power supply
  2. Heat issue
See if there are any logs on the switch that you can check for errors. If you can't I suggest you call 3Com for troubleshooting.
Oct 10, 2013 | 3Com SuperStack 3 3870 48-Port...
Connecting a 3Com 2952 Plus switch to a Cisco 3750 switch
If you also have a standard copper cable (or a second fibre cable) connecting the two switches (for resilience perhaps?), this issue is probably being caused by something called Spanning Tree. This is implemented on switches as a 'loop avoidance' system, and can look like you have described with one end 'ip' and the other end no lights.
On the Cisco switch, get to a telnet/ssh/console session, log in and enter show spanning-tree and press enter.
have a look to see if the fibre interface has a status (sts column) of BLK. If it has, then this is called 'blocking' and will remain like that until you remove the second link to the other switch.
Hope that this has helped!
Mar 03, 2010 | 3Com 3CSFP91 Transceiver
My 3com 4200 28 ports is restarting by itself many
Base from the description of your problem its only showing that some of the port on of your Ethernet switch is already getting bad and this usually happen on switch like this and eventually all port will go bad and will lead to the replacement of the device. With this type of problem you can first try to adjust the speed of your network card to 10 half duplex and check if that will correct the connectivity problem and if it does its just a sign that sooner or later the device is already getting bad and since its only a switch there's no firmware that we can load to it or even a reset button to bring the device back to its default settings.
Jan 27, 2010 | 3Com 4200 24-Port Ethernet Switch
Trying to connect 4 dsl routers to 48 port switch
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Feb 24, 2009 | 3Com 2250 Plus (3C16476CS) 48-Port...
Inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Dec 31, 2008 | 3Com SuperStack 3 4228G (3C17304-US)...
Problem with SW 4400 - restarting....
switch dont restart by themselves without command, first remove the switch from the network, disconnect from internet, make sure you hadn't fired anybody recently it sounds like a hack. reduce network traffic to local area only and priortise important internet traffic. now got back to the switch and troubleshoot make to check the reboot command on error or when error is found, if the problem stops when the switch is remove somebody is messing with the network.or the darn switch is faulty install a new one.
May 30, 2008 | 3Com SuperStack 3 4400 (3C17204-US)...
3Com 2250 Plus (3C16476CS) 48-Port Ethernet Switch Logo
1,045 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
