Question about Husqvarna Chain Saw 20" Bar
Leaking petrol my husky 50 chainsaw leaks petrol from somewhere below carb level when it is held in an upright position a new fuel pipe has been fitted so it is not that. any ideas to fix the problem would be appreciated
  • 211 Answers
Hi bob
Below the carb there are towards the cilinder:a gasket,a plastik suport and another gasket.Check the gaskets from there.Also the 2 bolts of the carb should to be tightened.
cheers savumihai71
Posted on Dec 15, 2008
Pls help me my Honda activa 125cc air pipe leak petrol heavy petrol leak pls help... I am scared...
Hi, Anonymous and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.xbhp.com/talkies/help-me/21532-petrol-drops-leak-over-flow-pipe-activa.html
Honda Activa Fuel Leak
http://www.motorscooterguide.net/Manuals/Honda_CH150_Service_Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda Activa Std Dlx Owners Manual
Jan 07, 2017 | 2005 Honda Activa
Why petrol leak in overflow pipe of pulsar 220?
Hi, Apurba and the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
http://www.xbhp.com/talkies/help-me/22718-pulsar-220-fuel-carb-drain-pipe-5.html
Bajaj Avenger 220 DTSi Fuel leak problem
Pulsar 220 problems or issues found and their solutions MaDrives Pulsar 220 problems or issues found and their solutions MaDrives
Mar 22, 2016 | Motorcycles
PETROL LEAK FROM CARB OVERFLOW XJR 1300
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
https://yamahaclub.com/forums/topic/28835-fj1200-fuel-leakage
Carbs leaking Here is how to fix it
Yamaha XJR1300 2007 Service Manual
OEM parts for Yamaha
YAMAHA XJR1300 Owner Manual
Jan 26, 2014 | Yamaha XJR 1300 Motorcycles
My chainsaw carbarator is not getting gas. model# 358357230
Chainsaws have all position diaphram carbs, this is because it has to work in all positions, one side of the carb will have a pump diaphram, this is actuated by a positive and negative pulse from the piston riseing and falling ( there will either be an impulse pipe from the crankcase to the carb, or a hole in the induction block and gaskets to achieve this ) the other side of the carb will have a metering diaphram, a needle and jets, this takes the place of a float bowl on a normal carb, as the engine is cranked the pump diaphram pulses, this in turn draws fuel from the tank via the fuel hose and filter. So if there is no fuel in the line, either the filter in the tank is blocked, or the hose is trapped,split or leaking, or you have no impulse to the carb.
Jan 02, 2013 | Garden
Could it be the inpulse pipe in the husky 50 rancher making it rave out some times
Certainly a fuel starvation issue, the impulse is a small rubber boot in the cylinder which seals a plastic tube in the back of the carb housing, if the boot has split it will cause problems, there is also a rubber indudction tube above it, make sure this is not split, fuel starvation can be caused by many things, blocked fuel filter in the tank, crack, split or bad fitting fuel hose, dirt in the carb inner screen, air leaks through crank seals or gaskets, lose carbs, incorrectly set up carb screws.
Jun 04, 2012 | Garden
No gas in carb husqvarna 141 chainsaw
Fuel gets to the carb via the fuel filter in the tank, the fuel hose up to the carb, and the impulse from the engine making the pump diaphram in the carb pulse and pump fuel, so start by replacing the fuel filter in the fuel tank, then check the fuel hose for signs of leaks, the impulse from the engine is fed through a pipe in the carb support block, you will need to remove the carb and block to inspect this, there is also a filter within the carb itself, this is sited under the pump housing of the carb ( alloy cover held with a single screw )
Oct 05, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Petrol leaking from the exhaust pipe Kawasaki Zephyr 550; high leak rate (more than 1 l/hr)
At least one carb is flooding badly and will need a clean, but the vacumn fuel tap is also leaking or it is in the prime position.
Mar 23, 2011 | 1990 kawasaki Zephyr 750
Hi, I have a 1999 RS 250 Aprilia and it has a strange leaking problem. When you turn the fuel on, a minute or so later on the left hand side engine cover petrol leaks out. There is no sign of petrol...
Hi, Teedon and the usual suspects are:
For more information about your issue please visit the websites below. Good luck and have nice a day.
DOWNLOAD 1999 Aprilia Rs 250
Oct 24, 2010 | 1999 Aprilia RS 250
Petrol leaking when turned up side down,Ryobi Chainsaw
Upside down is not a usual sawing position--only upright, or turned to the left or right side is recommended. If you need to undercut something, keep the saw upright and cut with top side of the chain/bar.This can lead to kick-back if the tip comes free of the log/branch, so you need to control the saw carefully. That's also why there is a chain brake on all newer saws. The leaking may be occurring where the fuel lines pass through the wall of the fuel tank. Hope this helps!
May 04, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Petrol leak exhaust
the unit is flooded...pull the spark plug and turn the unit over a few times to help dry it out.problem is that the crank case is also full of fuel.you can turn the unit upside down for a day to help the fuel out.install new spark plug,don't choke it,pull the trigger to full throttle pull the recoil ten times this will pull the fuel up to top of cylinder.remove spark plug pull a couple times and reinstall the spark plug.start the unit. if the unit floods again you have carb troubles.the needle is stuck open letting in too much fuel and it needs to be replaced.let me know if this helped.
Mar 11, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
104 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
