Question about Remote 2 T-harness
DRIVERS SIDE DOOR WIL NOT OPEN WITH REMOTE
ALWAYS HAVE TO OPEN DIVERS DOOR FROM PASSENGER SIDE
  • kugrysd Mar 22, 2009
    Drivers side door is not working with the remote, all other doors working, with the key everything works on Ford Focus
  • 3 Answers
Could be one of many solutions, but the common ones with this fault description are:
Door motor failure (get a replacement motor from main dealer or a breakers yard)
Switch failure (in the door, but unlikely in this instance if I understand your problem correctly)
A loom failure leading into the door, common on european vehicles (especially french ones)
Posted on Dec 14, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Key won't unlock driver door
the key or fob?
the key is bad,
use the spare key that came with all new cars.
always keep a spare. or get stranded.
Feb 22, 2014 | 2007 Honda CR-V
Drivers side door cant lock
this case the driver door lock have problem , need to replace ,try dis connect battery while all doors are open .
Apr 08, 2013 | Skoda Fabia Cars & Trucks
I get no heat out of the driver side vents,only the passenger side
If you have dual control. Then I would suspect that the plenum door actuator is bad for the divers side. These are a pain to get to , but not impossible. It is located on the drivers side under the dash to the left side of the console. You practically have to be a contortionist to get it. Always a pain in my back to replace. The motor it self is located 10 to 12 inches from the floor pan. has one plug going to it and the only thing there on the side of the plenum.
Oct 02, 2011 | 2004 Chevrolet Impala
I can't open the diver side door with the key or the keyless unit
handle may be broken from the inside of the door or the rod may be bent or disconnected. have to take the panel off to see it. when off, have someone pull the handle up a few times so you can look at it from the inside to see what its not doing
Jun 17, 2009 | 2001 Ford Explorer Sport
All doors open and close with remote except the passenger side ?
Sounds like the most likely cause is the electronic lock actuator is bad. will have to take door panel appart to check.
Jan 09, 2009 | 2000 Toyota Camry
Remote  2 T-harness Logo
166 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
